Phone/bluetooth help
Just got my 2011 Convertible and am really struggling with the voice activated phone.
Phone...Vehicle phonebook...john mobile...dial....
is there a faster way to tell the car to dial John's mobile?
The easiest solution is to program your favs in as speed dials so all you have to do is press the phone button and then select the # (entry) you want to call - either touchscreen or via steering wheel controls. You can add a voice tag to the speed dial too when you set it up too if you are hell bent on using all the features...
Good luck!
PS - welcome & congrats on the new ride. Cereral2K tells me that red verts are the fastest!
The voice recognition is a cute toy but I use it infrequently (mostly because I only drive the Vert with the top down and its disabled).
Good luck!
Good luck!
