Help 12 volt connection
12 volt connection
Hello Peeps ... I have a new throttle controller that I can hook up via my OB 2 or hard wire .. So my OB 2 Will not work for my 12 volt source and I have to hardwire . So where do I tap into for 12 volts. I have never done this before and I need help . I have to tap a 12 volt source and ground my negative wire . So any pros out there your info will help a lot .. Thanx Blaine
The easiest way is to tap into the fuse box (since I'm assuming the throttle controller will be in that general area?). Then just choose which fuse you want to piggy back off of (some are always on, some are on in ACC mode, some are only on when the car is on), the manual shows all this info. Then, use one of these for the easiest install, make sure you get the mini version since our fuses are itty bitty (these can be found at any auto store). They have the benefit of turning one power source into two.
Amazon.com: Bussmann BP/HHH ATM Add-A-Fuse: Automotive
Then, your ground can be any bolt that is attached to the frame. If you have a Fluke or similar voltmeter you can find a suitable ground source.
delfinparis
10-08-2015 06:06 PM
dedmanchan
09-24-2015 11:25 PM
