Blown HID Bulb 3 Times
Old 05-21-2011, 03:56 PM
_ant_
_ant_'s Avatar
Hey maybe someone can help me out. A week ago I received my V-LED D2S HID 6000k replacement bulbs. I installed them and when i turned on my lights only the driver side lit up. I removed the pasenger side bulb and saw it had blown.
Today i recieved the 2 replacement bulbs V-LED sent me and the same thing happened with both bulbs. I put the stock bulb back in and it worked fine.
Any idea what the problem is???
Jianna Circelli (02-03-2020)
Old 05-21-2011, 04:10 PM
Since you tired it with your OEM and they work fine, cheap bulbs sounds like the issue to me. Buy some quality, name brand bulbs and try it.
Old 05-21-2011, 04:24 PM
da mayor
da mayor's Avatar
There's a thread about HID replacement headlight bulbs that don't work when you turnthem on.
Old 05-21-2011, 05:04 PM
_ant_
_ant_'s Avatar
I guess i learned you get what you paid for lol. Any suggestions for a quality D2S replacement? Maybe Phillips Ultinons?
Old 05-21-2011, 05:05 PM
_ant_
_ant_'s Avatar
BTW sorry for posting this in the wrong section
Old 05-21-2011, 05:13 PM
Those are great but there are much cheaper premium bulbs that will work well.
GE, Philips, Sylvania, PIAA are a few that come to mind. I just had to change mine out and put my OEMs back in until my new ones arrive. Considering what a PITA it is to change the bulbs, I wouldn't do it any more than necessary.
Old 05-21-2011, 06:00 PM
_ant_
_ant_'s Avatar
Yeah its a serious PITA and very frustrating to change out the bulbs especially 3 straight times lmao.
I guess ill leave the bulbs the way they are for now (6000k VLED driver side, OEM passenger side lol). Ill research a quality bulb to use and change them out.
Old 05-21-2011, 07:02 PM
chuckie311
Drop A Gear and Disappear
chuckie311's Avatar
i found it really easy to chage the bulb. i just jacked up the car pushed the plastic fender well down and it worked out well..
Old 05-21-2011, 07:33 PM
_ant_
_ant_'s Avatar
^lol yeah its not frustrating when it works out the first time, but when you have to do it 3 times its a PITA
Old 06-15-2011, 07:02 PM
twin_snails
twin_snails's Avatar
I'm not sure if this applies to HID bulbs but I know that with older halogen bulbs, you had to make sure not to touch the envelop of the bulb so as not to get any oil from your fingers on the glass. The glass gets very hot and impurities on the bulb (i.e. oil from your fingers) and this can alter the cooling of the bulb which can cause hot spots. I had several bulbs where the glass actually bubbled (even though I made sure not to touch the bulbs) so I'm not sure if it was a cheap bulb or what.
Also, it's a good idea to clean the bulbs with rubbing alcohol before installation with a soft cloth. This will ensure that the bulb envelop is clean and free from impurities. Hope this helps.
Old 06-15-2011, 07:52 PM
_ant_
_ant_'s Avatar
i resolved the problem. it was because they were cheap bulbs, lol you get what you pay for. I upgraded to a more premium quality HID replacement bulb and it worked perfectly.
Old 06-15-2011, 10:24 PM
Invalid
Invalid's Avatar
What brand?
Old 06-16-2011, 04:17 AM
maxfinity
maxfinity's Avatar
Yeah, What brand did you upgrade to? My 10 dollar ebay bulbs are still holding up(Its been almost a year now) but in the event that they go out, i want to try some Higher quality bulbs to see if they're worth the extra pennies. I also want to go from 6000k to 5000k when these go out.
Old 06-17-2011, 04:15 PM
_ant_
_ant_'s Avatar
Originally Posted by Invalid
What brand?
Philips Ultinon 6000k
Old 06-17-2011, 04:45 PM
VossenG37S
VossenG37S's Avatar
I disagree , it's a known problem w 2011s for some reason they have similar issues reported from many friends have tried to run after market bulbs on the 2011. I'm running Vleds 5000Ks and ran there 3000Ks w never any issues. My buddy has the flicker issue on his 2011 w 5000K bulbs and another two guys have same problem. I could be wrong but just throwing this info put there.
Quick Reply: Blown HID Bulb 3 Times
