Does the G37 6MT have a neutral safety wire, ie. like the automatic does, so that the car knows that its not in gear? If so, where is this wire located. I know on the autos, it is located under the hood by the battery, but on the 6-speed, that wire is there, but has no signal. So where is this wire, if there is a wire?
This is from ECU. I used this wire to install my viper 5902 for remote start. You can find this tire from the harness right next to the ECU under the passenger side center console
