TSB to fix Call waiting issues on 2010+ Infiniti's
#33
Do you mean the music skips on playback with bluetooth mode? If so, I think this has resolved this issue for me as well. Not 100% sure as this was intermittent.
#34
Hey guys, this issue has been bothering me since I got the car in October.
I am seeing conflicting information now. This thread sounds promising, but I am reading here:
https://www.myg37.com/forums/audio-v...l-waiting.html
That looks like its still a no go? What is the TSB # I should give my dealership? Im bringing my car there Thursday for other issues and I;d like to have this done the same day (if it works)
I am using an iPhone 4 and 2010 G37s
#35
TSB# ITB10066
Should work fine for your car. Alot of dealers still dont know about the upgrade so you have to be persistent. Seems some people with Blackberry's are having problems with the latest upgrade, not the Iphone. Hope all goes well.
#37
Confused with this TSB!!
I have a 2010 G37 Journey + Prem + Navi. I had the dealer perform the TSB upgrade today.
With my iPhone 3GS (latest iOS), I dont see call waiting working . Not before the update , not after!! No change.
Also, I was reading that voice dialing works by hitting the Phone button and saying "Phonebook <voicetag>". This does not work either.
I have no way of getting voice tags to work. How are others with 2010 G's using voice dials ?
What is the indication that this TSB was successfully performed ?
#43
Actually, I am still getting the music skipping with bluetooth even though my call waiting is working now. (the call waiting was a much bigger issue)
#44
Looks like they updated the TSB
Could this be the TSB?
ITB10066
IF YOU CONFIRM One or more of the following is occurring on an Applied Vehicle: -- Audio streaming via Bluetooth is "choppy" or "clipped." -- "Calculating Route" takes an extended period of time (2-5 minutes) to complete. -- "Could not find aroute" displays when attempting to calculate a route. -- Voice Recognition sequence takes too many steps. -- With a device connected, the Navigation system reboots. -- When a hands-free call via Bluetooth is in progress and another call comes i n ("call waiting"), there is no function available to answer the incoming call. AND The Navigation system Program Version is not X1U72001 or X2U32001. ACTION Load the Reprogramming Software DVD referenced in the Parts Information section. See this bulletin for further detail.<!-- google_ad_section_end -->
ITB10066
- IF YOU CONFIRM One or more of the following is occurring on an Applied Vehicle: -- Audio streaming via Bluetooth is "choppy" or "clipped." -- "Calculating Route" takes an extended period of time (2-5 minutes) to complete. -- "Could not find aroute" displays when attempting to calculate a route. -- Voice Recognition sequence takes too many steps. -- Voice Recognition has difficulty recognizing voicetags. -- The Navigation system reboots. -- XM NavTraffic is slow to report. -- " Handset Phonebook" access is slow. -- When a hands-free call via Bluetooth is in progress and another call comes in ("call waiting"), there is no function available to answer the incoming call. -- Caller ID is not available when a hands-free call via Bluetooth is in progress and another call comes in. ACTION 1. Perform steps 1-6 of Confirm Navigation Program Version in the Service Procedure to verify whether or not this bulletin applies. 2. If this bulletin applies, load the Reprogramming Software DVD referenced in the Parts Information section. See this bulletin for further detail.
I have to get this done
#45
Thx Christian. I have to go in for the ITB10075 (Tranny Reprog) so i will have them do 10066 at the same time.
Do they not have "Revision" numbers on ITBs? I would think that the change Max pointed out would up-rev the ITB.
