Climate control not showing on screen
Hello,
I have a 2010 G37x coupe, i have only had the car for a month but have noticed that if i turn on or change the temp on my climate control it doesn't pop up on the screen. The only way for me to view the climate control settings is by pressing the status button. This isn't continuous, just happens 50% of the time. Anyone else have the same problem?
Thanks
Thanks
Hello,
Thanks
Thanks
Anyone have an idea as to an easy fix? I'm not going to take it to the dealer just for that....if I can't do anything or it doesn't work itself out I'll just have to wait until its next scheduled service.
Thanks, Mine had still done it over the course of a week. I haven't driven it much since i posted this to determine if this is an on going issue. Based on the number of replies i'm assuming this is not common and could be related to only my vehicle. Once summer arrives i'll probably revisit this issue.
Hello,
Thanks
Thanks
Hi
I have the same vehicle, about a year and half now, that happened to me for the first time yesterday, but it worked fine today. No idea why. I'm having a problem also with climate, when I set heat on footwell mode, after 15-20 minutes it switches to dash vent. You run into this problem?
Robert in Vancouver
Robert in Vancouver
Reflash?
Is it possible that this might be an issue listed in an TSB? You just might have to have the computer system re-flashed to get the latest code for this system. My 2012 hasn't had this problem. Also read the owners manual because some things don't appear depending on what mode you might be in. This is more true on the NAV system from what I can determine. Good luck.
Al
Al
@beatles<O</O
<O</O
I have the same problem with my HVAC switching from the floor to the vents.<O</O
<O</O
https://www.myg37.com/forums/general-tech-questions/241460-hvac-switching-on-its-own.html
<O</O
<O</O
Hello,
Thanks
Thanks
Hello,
Thanks
Thanks
