Subwoofer in Vert
Subwoofer in Vert
May be wrong place but can't find anything on this. I had a sub system in my G coupe w/sub tied into Bose system w/ a custom enclosure. Obviously can't do that w/ a vert. Has anyone replaced the stock sub behind the back seat in their vert? I'd think you could replace the sub w/ aftermarket, tie into either the sub signal from bose system like I did before or even use a line level converter to knock speaker level signal down. Put an amp in our tiny little storage space and ready to rock. Is the stock a standard 10" job? Thoughts?
I have a spare tire so that is a no go...can't ditch it as I drive 60 miles round trip to work and have had flats before from road trash...not an option. I was hoping for a bolt on solution to replace the stock sub w/ a more efficient one plus some extra "juice". Darn, gonna have to take it all apart to see what I've got. Thnx
Can someone please verify the location of all the speakers in the Vert? I didn't even know there were subwoofers located behind the seats. There is not a specific subwoofer adjustment - the only thing you can adjust is the base, which sucks if you ask me if there truly is a subwoofer in our cars!
3 in each door (6 total)
2 in each head rest (4 total)
1 in center dash
1 in center dash
There are 13 speakers (Bose/Nav).
1.Center speaker
2.Tweeter LH
3.Door squawker LH
4.Door woofer LH
5.Driver headrest speaker LH
6.Driver headrest speaker RH
7.Rear woofer LH
8.Rear woofer RH
9.Passenger headrest speaker RH
10.Passenger headrest speaker LH
11.Door woofer RH
12.Tweeter RH
13.Door squawker RH
1.Center speaker
2.Tweeter LH
3.Door squawker LH
4.Door woofer LH
7.Rear woofer LH
8.Rear woofer RH
11.Door woofer RH
12.Tweeter RH
13.Door squawker RH
2010, convertible, coupe, dashheadrest, g37, g37s, infiniti, myg37, replacement, spare, subwoofer, subwoofers, upgrade, vert, woofer
