Hello you, how do you install a subwoofer amplifier to a Bose system??
+1 on this. Did you happen to take pictures of the cables you spliced to connect your amp? I have my system ready just want to see what cables you used.
The wood is kind of just wedged behind the metal frame of the back seat, its a really tight fit. Then with the amp bolted in place it holds everything together.
I didn't take pictures of the wires that I tapped into or anything. I just used a couple D.I.Y's on this forum along with the Bose wiring break down sticky in this section.
Luckily a buddy of mine used to install systems at a shop so he did most of the work.
If you have any other questions I will do what I can to help.
