People with aftermarket systems...is nav and bluetooth audio working correctly?
Old 07-29-2010 | 07:17 PM
gundam83's Avatar
gundam83
Just recently got my system installed which consisted of aftermarket comps up front, 2 12" subs in the rear, a 5-channel amp to power them, and a jbl ms-8 processer. However I've noticed that my navigation audio is super low and bluetooth phone calls is all but unusable. I'm guessing with the bluetooth, that the ms-8's processing is to blame, however I can't explain the nav audio.
I'm seriously considering pulling the JBL MS-8, but before I do, I want to know if the problems I've experienced does not exist for people who are just running a straight connection to their amp(s)?
Old 07-29-2010 | 07:21 PM
Dmac324's Avatar
Dmac324
I am running a straight connection to my amp and have no problems whatsoever
Old 07-29-2010 | 07:23 PM
gundam83's Avatar
gundam83
Are you just grabbing the front left and right channels from the factory harness and hooking them up to the amp?
Old 07-29-2010 | 07:27 PM
Dmac324's Avatar
Dmac324
sorry but i cant answer that much, i didnt do the install, all that i am positive about is that its running straight to the amp
Old 07-29-2010 | 07:45 PM
gundam83's Avatar
gundam83
Thanks. I appreciate any helpful info I can get.
Also anyone running just front comps and a sub and have the center channel disconnected?
Old 07-30-2010 | 03:56 AM
Cobalt232's Avatar
Cobalt232
I have ms-8 installed and have no problem with the navigation. Don't know about Bluetooth, I haven't used it since I installed the audio system. Make sure you have the navigation volume turned up.
Old 07-30-2010 | 04:23 AM
gundam83's Avatar
gundam83
Navigation audio is up. Can you tell me what you used for inputs for the ms-8. I'm wondering if I may have fubared something.
Old 07-30-2010 | 04:34 AM
Cobalt232's Avatar
Cobalt232
I used the front left and right signal coming from the HU to the bose amp. Just tapped into the wire with a RCA cable that I made. Are you using the signal FROM the amp or the HU?
Old 07-30-2010 | 04:37 AM
Cobalt232's Avatar
Cobalt232
This is what I tied into.
(33) Front Right + (R)(Red) **Preamp from HU
(34) Front Right - (G)(Green) **Preamp from HU
(35) Front Left + (P)(Pink) **Preamp from HU
(36) Front Left - (L)(Blue) **Preamp from HU
news1213
12-16-2015 12:06 PM
warpeacelove
10-28-2015 03:59 AM
OBG37
08-27-2015 04:56 PM
Quick Reply: People with aftermarket systems...is nav and bluetooth audio working correctly?
