LCD display almost died b/c of heat
Old 07-07-2010 | 07:57 PM
bobmcc's Avatar
bobmcc
So today getting into my '08 coupe after work at 330pm after the car was parked in the sun all day (with temperatures around 100 degrees here in Philly area) I started her up and the LCD info display (between the speedo and tach) was totally blank. Yes I checked to make sure the dimmer was on max. During the drive home the display would go from black to very dim to black again. I pulled into my garage and went out 3 hours later and all was normal again. I assume it was from the heat and no permanent damage was done. Has anyone else had this problem?
Old 07-07-2010 | 08:13 PM
deepFlip's Avatar
deepFlip
weird stuff.
i live in PR and we have those temps all year round and i never witnessed nothing like that.
imo get it checked by the dealer.
Old 07-07-2010 | 08:17 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
yeah during the summer here in SC it is definitely over 100 each day and I leave the G parked on the flightline and have never had that happen...time to go to the dealer
Old 07-07-2010 | 09:15 PM
G37SBS's Avatar
G37SBS
i also parked my G37 all day under the sun and i don't have that problem yet...
Now i'm worrry whether i should park under the sun or not because of the extreme heat..
Should we worry about that??
Old 07-07-2010 | 09:48 PM
SleepyMonkey's Avatar
SleepyMonkey
No. If a G survives in Puerto Rico heat it will thrive anywhere - that place is HOT! I agree that OP needs to go to the dealer to have it checked out.
Old 07-07-2010 | 10:46 PM
Eastern-G's Avatar
Eastern-G
My 2010 has been outside in the crazy weather but no issues with the little LCD screen. However, I did have problems with my iPhone connection right after starting up the car. Kept disconnecting and locking up - never happened before. Strange, perhaps due to the iPhone itself or maybe the heat (103 degrees!). Never thought I'd be wishing for some rain!
Old 07-07-2010 | 10:50 PM
BHB 91's Avatar
BHB 91
My G has been subjected to temps over 105 in the Dallas area with no problems other than burning my *** getting in after work! Seriously though, time to go to the dealer.
Old 07-07-2010 | 11:18 PM
MrBig's Avatar
MrBig
Parked at work when it's 105 - 118 from late May through October. No problems here.
Old 07-08-2010 | 06:00 AM
KhaldeanHabibi's Avatar
KhaldeanHabibi
i have a issue with the screen twitching when its hot outside im taking mine to the dealership though if they say anything about it ill let u know
Old 07-08-2010 | 08:08 AM
09G37xCpe's Avatar
09G37xCpe
I'm a little bit north of the op (not too far north though) and mine sits outside all day every day at work and I haven't had any LCD issues. I'd go back to the dealer to take a look at it.
Old 07-08-2010 | 05:58 PM
ShyTown91's Avatar
ShyTown91
ive never had it happen but im not surprised it did. electronics do that in extreme heat from time to time. i wouldnt consider it a problem unless it happens repeatedly
Old 07-08-2010 | 06:06 PM
2muchredbull's Avatar
2muchredbull
115 today in phx AZ and i have had no problems but i have only had the Vech 5 days, only prob i have is trying to find something to cover shift *** from when i first get in, i kid u not you can get 1st-2nd degree burns from that ****
Old 07-08-2010 | 06:38 PM
xixonmn's Avatar
xixonmn
Tinted windows and windshield sunshade will fix that problem. I got the custom sunshade from Infiniti dealership for $35. It helps a lot.
Old 07-08-2010 | 07:24 PM
SleepyMonkey
I hate my shift *** for that reason. They were handing out cell phone "socks" at Sweetwater Brewery a few weeks ago. I have no intention of using it with my cell phone, but I do put it on my shifter to save my hand!
Old 07-08-2010 | 09:50 PM
eksigned's Avatar
eksigned
that's probably not from the sun. i'd imagine that if there's a problem with the lcd in the tach because of the sun, other lcd screens, like your navi would also have issues. isolated issue. dealership run
