LCD display almost died b/c of heat
Old 07-09-2010 | 12:46 AM
MrBig's Avatar
MrBig
Originally Posted by 2muchredbull
115 today in phx AZ and i have had no problems but i have only had the Vech 5 days, only prob i have is trying to find something to cover shift *** from when i first get in, i kid u not you can get 1st-2nd degree burns from that ****
You need a Michael Jackson glove, I got a blue one!
Old 07-09-2010 | 05:47 PM
bobmcc's Avatar
bobmcc
Originally Posted by bobmcc
So today getting into my '08 coupe after work at 330pm after the car was parked in the sun all day (with temperatures around 100 degrees here in Philly area) I started her up and the LCD info display (between the speedo and tach) was totally blank. Yes I checked to make sure the dimmer was on max. During the drive home the display would go from black to very dim to black again. I pulled into my garage and went out 3 hours later and all was normal again. I assume it was from the heat and no permanent damage was done. Has anyone else had this problem?
2 days Later update---------
The last 2 days the temps were mid to upper 90's. LCD was fine, no futher problems. My next oil change I will mention it to the dealer.
vamarris
12-09-2018 12:10 PM
MrRiv
09-29-2015 05:59 PM
m3clubracer
09-28-2015 04:45 PM
dedmanchan
09-25-2015 12:25 AM
