Which amp to get for Alpine Type R SWR-1022D
Looks like I'm going to be buying 40800 box with a Alpine Type R SWR-1022D subwoofer and wondering about your opinions on which amp to get -
I'm
MTX Jack Hammer JH600 monoblock
Rockford Fosgate P600.1
Kicker zx400.1
The subwoofer specs are:
2+2 Ohms
<DT class=alt sizset="124" sizcache="23" jQuery1272289615071="30">Power Handling Max <DD class="">1500W
</DD><DT class=alt sizset="128" sizcache="23" jQuery1272289615071="32">Power Handling Nominal <DD class=alt jQuery1272289615071="43">500Wv
2+2 Ohms
</DD><DT class=alt sizset="124" sizcache="23" jQuery1272289615071="30">Power Handling Max <DD class="">1500W
</DD>
I'm
Kicker zx400.1
2+2 Ohms
2+2 Ohms
</DD>
You'll want a 1 ohm stable amp for sure, that way you will crank the most out of the amp. When you wire it in parallel you'll get 1 ohm, series 4 ohms.
If you can get the Fosgate, definitely do that, those amps are absolute beasts, they will put out more rms than rated.
For wiring use 4 gauge power and 12 guage to the subs, knuconceptz preferred.
flyingnimbus
10-03-2015 12:12 AM
