Help: Navi and XM
Help: Navi and XM
I briefly searched and found nothing.
Anyway, I just bought a used 08 coupe sport, and it seems a lot of the options on the nav and XM are greyed out so that i can not select them, such as set a new destination. it has all the old destinations/routes from the previous owner, and i can not figure out how to delete them or just reset the whole thing.
also, I activated my XM, but it only seems to scroll from channel 1 to 0 to 240 something. is this normal? is there a reset button for all this? thanks
for the nav, you have to be stopped w/ the parking break on for all the stuff to be lit up...if that is still not working then I am not sure what the problem is
for XM, if you don't get all the channels you can call XM and ask them to resend the signal to you (there might be an option for it but Im not sure, look through the nav unit manual)
haha..thanks. i didnt think to pull the e break and all that. my wife was messing with the nav while i was driving home and we couldnt figure it out. thanks again
Senior Citizen
But in essence, you can have your cake and eat it too by imputing destinations while moving via voice commands. You would be surprised how well it works. I have found it is often faster than manual inputs. You can even have a passenger do it (All you have to do is press the steering wheel button on cue). Try it—put in some long street address manually and time it; then do it again via a voice command. You may be surprised at the result.
i havent set my voice controls up. will have to try it. i had an eclipse unit in my 350Z that i grounded to a general bolt that allowed DVD/navi/etc. on the fly, but i am not even going to attempt messing with the stocker navi
THE EBRAKE DOES NOT HAVE TO BE UP IN A 6MT WITH NAV!!!! You just have to be at a stop.. if the car detects you are moving it will block you out from certain menus.. play with your car and youll figure out ways to do things while driving. if you need help pm me.
Maybe one of us has it wired wrong or something . Or it's different in the sedan vs coupe.
