Problem with iPhone phone book download and 2010 G37
well. So much for that.
My phone book showed up corrupted this evening. Lasted about 5 days. I'm going to call infiniti consumer affairs again to tell them that the workaround didn't last.
Bummer. Well, I guess the standing workaround will be to configure it not to sync the address book on every connection once the proper one has been transferred. My contacts change every 6-9 months top anyway. Hopefully they'll fix it soon...
I would love to know how you get the phonebook transfered. I tried bluetooth and got no where. Do I need to use USB connection?
I called infiniti consumer affairs to update my reference number with the info that my workaround didn't stick
Anyone else seeing this problem, please call 1-800-662-6200 and report it. I'm hoping that the more reports there are, the more likely they'll fix the problem.
jwest54, the phonebook transfer only works in the new '10 integration. I don't know if it's nav specific either. So if you have a previous year model or don't have nav, take all this with a grain of salt
. The bluetooth integration now has separate vehicle and handset phonebooks so if you pair a bluetooth device and it supports phonebook syncing you'll get two phonebooks, one on the vehicle and one on the handset. Look under the "Phone" menu and if your system supports it you'll see "Vehicle Phonebook" and "Handset Phonebook"
![Frown](https://www.myg37.com/forums/images/smilies/frown.gif)
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
Two questions:
1. This problem only occurs if you attempt to use bluetooth both for handsfree and music streaming, correct? In other words, if I use bluetooth for handsfree and the USB connection for music, there won't be any corruption to the contacts?
2. Does the 2010 G37 charge the iPhone 3G/3GS through the USB port? I don't want to see any of this 'unsupported accessory' nonsense!
Cheers,
bm~
Cheers,
bm~
I called customer service and spoke to a tech. and I got the feeling that they feel its a phone problem and not an Infiniti problem. They seemed to be aware of the problem. Solution seemed to be to "live with it". I explained to him the workaround but that it didn't seem to be holding and that it was suggested to not use auto download and see if that worked. I gave him the info on the forum and the thread and he was going to look into it and asked if he could call me next week. Thanks to this forum I gave him more info than he gave to me.
Good to know, but I'm disappointed that Clarion didn't fix this already. It's not like these phones are particularly new to the market.
okay, I paired my iPhone as just a phone, no audio device. Phone book corrupted already
. There's go to be some method to the madness here, but I haven't figured out what to do to consistently cause the corruption.
Yeah, mine went about a day without corruption and then got corrupted last night. Like I said, I'm going to have it sync contacts once and then disable sync on each connection. That should act as an effective workaround for this while folks keep hammering on it.
did you disable contact sync on the phone and auto downloading on the car? or just one or the other? I did both this time around. I seem to recall trying the disable sync once on the phone and it didn't solve the problem, but that was in the first couple of days of noticing it, so I hadn't started doing tests scientifically yet.
#29
#30
J
