Which Viper Alarm should I pick?
I'm think to install a viper alarm with at leasat tilt sensor alarm, impact sensor, and 2 way.
Could you please recommend which Viper should i choose? some people recommend 5002, but is there anything simlar, or this is the one to go?
How about any reputable installer in LA area?
Many thanks for all ur help.
i have a hornet 727t in mine, so it works with the factory keyfob..
I did try the 5901 and had tons of problems. it could have been my installer, or the hardware itself.. i don't know. anyways i would recommend you check out the 5902, its the latest one out.
uh well what kind of help are you looking for?
Any viper alarm will work, just gotta find a good installer. The features your looking for: tilt sensor, motion sensor, glass sensor, those are all add-ons. you have to buy those separately and pair them with the main viper unit.
If your looking for someone to tell you where to get it installed, that may be harder. just go to the viper website, look up installers in your area. give them each a call, check prices. then go into the shop and ask to see some installed work, and just take a look around.
A good installer is a NECESSITY. bad ones will make your life a living hell.
Thirty_Seven
09-18-2015 11:34 PM
