Help My Navigation is Stuck
My Navigation is stuck on a point and the arrow makes turns as i turn around that one point and wont move. Anyone know how to reset it. not the configuration but the system itself?
![](/images/banned.gif)
read it and try it........... if it works out..... you have the KP thing
if it doesnt work, that means a trip to the dealer....lol
To change the programmed state you must hold the ‘OK’ button down for approximately
15 seconds. Once the button has been held down long enough the AUX output will pulse
on and off 4 times to provide indication that programming mode has been entered.
lets put it this way i can watch movies while im driving and it screwed up my navi...i bought mine brand new. i went to a guy and he told me what i did instead of using an on and of switch with 2 poles i used one with 3. so thats why it got stuck. i just have to change the switch. And it should be fine
i have tried to disconnect the battery and it reset and then about 20 minutes later it seemed as if it had a stagnant connection. like it was behind like i was 3 blocks ahead and it showed i was 3 blocks away i stopped by my house and waited 3 minutes and it showed me 2 blocks away.
See all you had to do was follow directions...why would u use a 3 pole switch when the instructions clearly stated which one to buy? What happened with you is that your VSS wire was being grounded permanently instead of on/off.
A "3 pole" switch (which I am assuming you mean a 3 pin not 3 pole) could work if wired properly. It sounds like you connected the NC pin to the NO pin and therefore no matter where the switch is it won't work. All you would need to do is swap either one of the pins you are using now to the other pin that isn't being used now and it should start working.
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
