Aftermarket Wireless Rear View Camera
Old 06-19-2009, 03:17 PM
kkokko
kkokko's Avatar
Check the link out, I think i found a solution. The toggle switch is to turn on the NAV display, when you put the car inreverse it will switch the display to backup camera.
https://www.myg37.com/forums/audio-v...version-2.html
Old 08-30-2009, 05:54 PM
sg37
sg37's Avatar
Hey guys,
I'm reading the VCI-NIS1 manual and I have some questions.
1. Connecting the power supply wires:
- Connect the VCI-NIS1’s BLACK wire to chassis ground.
- Connect the RED wire to a switched +12 volt source.
Q: Just tape the black wire to the ground? Which +12 Volt Source? cigarette lighter?
2. Wire the VCI-NIS1’s BLUE wire the vehicle’s +12 volt reverse light supply wire. The reverse wire will show +12 volts when the vehicle is put into reverse.
Q: How do I find the reverse signal cable?
3. Wire the VCI-NIS1’s GREEN wire to the vehicle’s negative parking brake supply wire. The parking brake will show continuity to ground when the parking brake is on.
Q: Again how do I find the cable?
Thanks.
Old 08-30-2009, 05:57 PM
kkokko
kkokko's Avatar
i got that module working on my g37, but i had it professionally installed so im not sure the details..
Chris Olson
03-28-2024 09:46 AM
GXXXVII
General Tech Questions
12-11-2021 08:58 AM
Thedbarz
33
02-09-2016 12:05 AM
jessebritches
08-20-2015 12:40 AM
Quick Reply: Aftermarket Wireless Rear View Camera
