having some trouble with voice controls and nav
3 questions so far about the new car
1.) how do i change its "home" setting on the navigation, its set to michigan address i need that changed to NJ
2.) when i click the talk button it says only navi or telephone.....i thought i could do climate and audio controls with this also????????
3.) when i use the navi and search for a restaurant its not finding them well and only showing the first 5 results, if the restaurant is not in the first 5 then im screwed?
1) Have you checked the manual?
2) Yes.
3) Sometimes
__________________
2) Yes.
3) Sometimes
__________________
Users guide/manual will have the answer to the others...
Just to add to what everyone else said:
1) saltfish is right; this is where you would go to change your home address, or any other address's you have saved. just click on which address you wish to change.
2)what the others were saying about the stripped down controls is true unfortunately.
you can still command some of the climate/audio though, kinda. you can turn on/off the climate control as well as turn on/off the audio and pick the source of music(ipod, satellite radio, cd, etc.) with the voice commands.
3)if your moving while doing a search for nearby places, the list will only display the first five. you'd have to stop to scroll through the whole list, kinda sucks. infiniti has it this way b/c of "safety reasons", much like all the other grayed out areas of the system you cant access while driving. there are ways around this however.
delfinparis
10-08-2015 06:06 PM
mjnoles1
10-04-2015 10:27 PM
Murkr
09-28-2015 10:45 AM
