Is it possible to put a 350z Homelink in a Base G37?
I have a 2004 350z that i'm turning in to nissan (lease ended) it has a homelink on it and i want to take it out and put it in my 2008 base g37. Is that possible?
It is very possible. There wont be any plugs for it, you will have to tap your own wires. The mirror just needs 1 +bat 1 +ign and 1 ground. Should be pretty easy.
does your base 37 have the wires up by the mirror to plug it in, if so, i would think its the same.
not that i can find.
now where can i find the ignition wire to tap into?
