Help What did i screw up???
The reason I asked about the lights being turned on is because that is controlled by the BCM - it seems the BCM is functioning properly.
From your added details it definately sounds like the Unified amp and A/C meter is not getting power when the vehicle is off. I would be optomistic that it should be an easy fix (ie a blown fuse)
Also, I added a diode and now the shift light and traction control memory work well together.
![](/images/banned.gif)
I would starty by checking the 10A fuse marked 6 in the drivers kick panel (or passengers I guess it would be on the new cars).
That is the fuse for the Unified Meter and A/C Amp. When checking the fuses use an ohm meter if the "look" good because sometimes a hairline crack is all that will stop the fuse from working. If it is obviously blown then a meter isn't necesarry!
I've just finished installing a Calibre K40 Radar/Laser detection system, and the following modules from KPTechnologies: Window Rollup, Sunroof Close, Shift Light, Navigation Bypass, and Traction Control Memory.
Now, I have the following 2 problems:
1) My Supplemental Air Bag Warning light constantly flashes
2) My instrument cluster lights reset to the dimmest setting each time I start the car, and it goes to the instantaneous fuel economy display
Any thoughts????![Confused2](https://www.myg37.com/forums/images/smilies/confused2.gif)
Any thoughts????
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
All the other stuff came from KP Technologies www.kptechnologies.com
37
10-17-2020 11:12 AM
delfinparis
11-16-2015 02:26 PM
Jonesmeister11
09-27-2015 08:28 PM
User 122320
09-25-2015 08:10 PM
airbag, blows, brain, calibre, dpjonesmsncom, fuse, g35, k40, navigation, problem, procedure, radar, reset, supplemental, warning
