Our NAVs SUCK!
my acura nav allows me to set most direct, quickest and shortest distance. They are not always the same thing. Sometimes the fastest route is longer distance wise but uses more highway....Make sure in setting you have the right way set and if u can choose make sure to set highway speeds appropriately too if that exists in settings
well I dont have the infiniti yet but on our mdx if u have it set for shortest distance instead of direct route or quickest time it might give u a route that is fewer miles but on slower route...
I would look through routing settings first
Don't get me wrong... Locally I have 0 problems!
I beg to differ... See below for the Nav's determination of the fastest vs shortest route.
This shows what Infiniti Nav says is the Shortest Time...
This shows what Infiniti Nav says is the Shortest Distance...
Ummm... Why is the Shortest Time about and hour and a half longer than the shortest distance? Wouldn't these be the same?
EDIT: Even Min Freeway has a shorter time than the Shorter Time Option.
I agree our nav systems suck a**! I have had 2 Acura's and their nav systems are much better and easier to use in my opinion. Plus some of our options black out when you are driving which is retarded. I'm a grown a** man, if I want to type something or go thru my nav system that is my option damit especially if I am driving a $45k car!
The problem is not Infiniti's, but the manufacturer of the NAV.. who's name escapes me right now. It the programming that they have on the individual routes that need to be updated. Don't confuse the two.
