Rear speakers observation
Hi there,
I tried to sit in the back seat, and found that the 2 Bose speakers in the back (under the rear glass) do not make much noise. I tried to turn all the noise to the rear and I heard that most of the sound were coming from the side. Those 2 speakers even though they look big, but does not provide much sound. Anyone feel the same?
Those are not your woofers, your subs are in the doors. You have 2 10" subs in each door, my rear speakers put out alot of sound actually. The only problem I have is when I turn it up the rear speakers sound like they are rattling or they are making the rear glass rattle because they are so close, its not really that bad. I have to get that looked at though
Thought of something as I sat here, have you tried to go under your audio controls and turn on the "driver's stage" function? I have mine on, dont know if it makes a difference but you could try that.
Hi there,
The rear speakers are not subs. They handle the mid range the best but they do some highs and lows as well since I believe they are 6x9s.
I guess I am trying to say is that rear speakers are not as loud as I thought they should be. It sound like most of the sound in the rear are mainly from the side speakers. Maybe someone can sit in the back and listen and see if u think the same way.
FYI: I tried both Driver's stage function ON/OFF too.
Thanks guys/gals.
Thanks guys/gals.
I was in the back last weekend and I know what you mean. The rear speakers are not that load and I think it was designed that way by Bose so the sound is more balanced in the front. I was in the back of my car and I didn't think it sounded that bad though. I was a little intoxicated at the time so maybe that is a factor.
