bluetooth FAIL
I have a similar problem which might be related. I don't have the Iphone but what I find is that for incoming calls from people I have set up for special rings (A voice message of them saying "Answer the Phone It's Me") I have the same problem. The BlueTooth doesn't recognize that a call is coming in at all or I answer and they can't hear me but I can hear them. For all other calls with regular rings it works fine. To solve the problem, I set the phone on vibrate when I am in the GEE and it works fine.
This is a pretty well documented huge bug between the Nissan/Infiniti head units that have on board navigation (the non navi head units aren't effected) and most Windows Mobile 6.1 Phones.
I am pretty sure the OP has a Windows Mobile smart phone running 6.1 because these are the exact symptoms. What you hear is garbled and the person on the other end hears nothing.
There is a work around where u can hit the "use handset" button on the navigation screen then hit the "use bluetooth" (or whatever it is called) to switch back to the car. Apparently that fixes the issue, but you have to do it for each call.
I wish we could get a more organized petition or complaint to Nissan/Infiniti and Microsoft so they could figure out the issue.
One good piece of news is that the HTC Mogul (which is a phone that exhibits this problem) is on the Infiniti compatible phones "test list" so they must be aware that there is a problem if they are actually testing it.
delfinparis
11-16-2015 02:26 PM
delfinparis
10-08-2015 06:06 PM
