help! Need to know signal wires to tap by color
Hey people! I've gone thru many threads to help install my amps and Im about 90% sure with what Im doing .. Just need a lil clarification... Let me start with what I have understood.. I have premium pkg so Car contains a Bose amp and woofer amp.. Bose amp has 2 harness and woofer amp has 1 harness. Wires from hu to Bose amp are flat which I assume is the left harness with all thin wires.. Which then means harness to the right with both thin and thick wires go to speakers with signal being equalized and not flat anymore .. Correct so far? So here what I'm trying to do: I want to install 2 amps; a 4ch fosgate amp for speakers and a mono mtx amp for subs: I want to tap RCA plugs to the wires cumin from hu cuz its a flat signal ..so it would be a total of 6 RCA I'm want to tap 4 for fosgate and 2 for mtx. So here are my questions: and please dont answer wit b43 or terminal #8 becuz there not labeled so I wouldn't know which is which.. So please answer wit color wires
1- do I tap into left harness of Bose amp, if yes are both amps tapped into it?
2- can u give me color of wires for all speakers fl,fr,rl,rr , woofers..etc
I'll be doing this same thing soon as well. I just downloaded the factory service manual so give me a little bit to read through the electrical dagrams and I'll make a sticky for everyone that details what color wire does what for the Bose system at the amps.
Please keep in mind though that if replacing speakers, the color of the wire at the amp is probably not the same color at the speaker. Nissan loves to change it through several connection harnesses!
KZK
Canada
09-02-2015 05:30 AM
