Simple JL Install
Old 03-21-2009 | 08:20 PM
  #46
ironchef2008's Avatar
ironchef2008
Hey Max,
Here's a few tips I use and it's what's recommended by JL:
  • Turn off Bass EQ and adjust gain/input sensitivity first
  • Turn on Bass EQ
  • Start with a "Q" of 1.6
  • Set the Crossover to 45Hz
  • If you're sub is in a ported box, turn on the infrasonic filter. If it's sealed, turn it off
Don't forget that these features only work in LP mode. My final settings for a JL 10w6v2 in a 4080 enclosure are:
  • Bass EQ on
  • 12 db slope
  • Q of 1.4
  • Crossover 40Hz
  • Infrasonic Off
  • RBC-1 Bass Controller installed between heater switches to control boost
Hope this helps. Feel free to PM me with any other questions or concerns. Good luck!
Old 03-21-2009 | 08:25 PM
  #47
Airborne Guy's Avatar
Airborne Guy
  • Bass EQ on
  • 12 db slope
  • Q of 1.4
  • Crossover 40Hz
  • Infrasonic Off
Do you think these setting would transfer well to a 250/1 with the same sub and enclosure?
Old 03-22-2009 | 08:22 AM
  #48
ironchef2008
The 250/1 doesn't have all of the features of the 500/1 but I would recommend the following:
  • Infrasonic off
  • 12 db slope
  • Crossover of 50Hz
Also, I don't think I'd run a 10w6v2 with a 250/1. It just doesn't have enough grunt to push that sub properly. It would work great with a 10w3v3 or the new 10w0v2.
Landshark
08-26-2015 09:19 PM
G37xS-Life
08-24-2015 12:08 PM
cparise
08-19-2015 01:51 PM
Quick Reply: Simple JL Install
