Inside door pics of Premium Audio cars
#61
Thanks.
Unless you're running more than 150 watts, you might save some $$$ using the stock wire.
Did you measure the stocks to determine what gauge they are? I eyeballed them and they looked ok but I didn't actually measure the size.
On the Bluetooth, I've found the volume much louder with the new set up. I'm not sure that the center is used for music though it might be. If it is, I might look at using the 3sixty to work with it. They have a center channel on it. Of course, if ithe center is available, I might have to put a Dyn in there, too.
I've got to play with it for a while before locking down the configuration.
#62
Thanks.
#64
Nice setup. I really don't think you need the stock tweets and center channel for imaging. With the fosgate 3sixty.2, you should be able to properly tune your sound stage without the factory tweets and center channel. It would only hurt your imaging. My set up with my morels is just the 9' mid subs, 3.5 inch dome mids and 1' tweets on the doors, my center stage is full without the factory center channel installed. With a little creativity, all of 3 speakers are mounted with at factory location.
I'll be posting pics soon
#65
#66
#67
Not a problem. Gonna be down for some amp 'demo testing' soon?
Control will be via a Denon receiver (midline) and an Eclipse ECD510 along with Dynaudio 52SE monitors. I got a few to play with .. Sinfoni/Alpine F1/TRU Billets and Steels/Genesis DM/Arc SE/ and a really sweet Celestra VA210. Im sure a few more will come out to play as well.
Double blind folded of course.
#68
#69
Thanks.
#70
