Ipod Equalizer
Ipod Equalizer
I was trying to test the Ipod equalizer settings (which I set in itunes) in the car by playing the same tune with different equalizations but I could not tell the diffrence. My Ipod's equalizer setting is on "flat," as it works on any other system.
I've been told that I'm going deaf so with that being said...
Do you know if the head unit fails to recognize the equalization setting from the Ipod?
When you set your iPod to Flat, all songs will have "Flat" equalization regardless of your settings in iTunes. You want it set to "Off" instead to have each song have their own EQ that's set in iTunes.
http://www.apple.com/batteries/iphone.html
See "Turn off EQ:" from the page above for Apple's explanation.
If I set the equalization on my IPod it makes a difference when I play music. So if I change it to "bass boost" then it gives the some more bass etc. Not sure if this is what you are talking about though.
But depending upon the songs volume level and volume boost setting in iTunes for the song, it is very easy to clip the song and overdrive the headunit causing distortion. Its best to turn it to flat or off (if you don't have settings in the songs) and control via the headunit.
Thanks, I had it backwards... I feel kinda stupid but that's okay I will test it again with the "EQ off" on the Ipod
Yes, this was my assumption. So I guess you did this by setting the Ipod EQ to off... Thanks
You are correct, but if you set it up right, I think that you can achieve a better sound with our "premium" system. I will test it to double check.
I have put my IPod eq to bass boost on certain songs that the system couldn't get the bass to hit without turning the sound up very load. One of them was a White Zombie song but I don't remember the name. I was like this song is suppose to have a hard hitting bass track that sounds dope. Let me try putting my IPod on bass boost. It sounded so much better when I put the IPod on bass boost...
I might need to try that "rock" setting. All I know is I played "More Human Than Human" (that was the song) and was like WTF. This sounds flat and like crap. Set the IPod to Bass Boost and it sounded great. Then of course JayZ came on afterwords and the bass boost made that sound like crap so had to turn it off.
bluej20
09-29-2015 03:57 PM
Juancgn33
General Tech Questions
09-14-2015 05:49 PM
sharmelan
17
09-14-2015 03:18 PM
Juancgn33
09-01-2015 08:44 AM
