Where to draw the signal from for the sub?
#61
Well the installer is trying to tell me that the Infinity basslink II I'm installing (only for the time being, I want a full, much better system) needs all 4 inputs to work right. He tried telling me that the sub will only get half power with just 2 rca's, but I was not buying that. I'm not stupid. The rca's supply the sound signal, and have zero to do with power to the sub. Does anyone know if there is truth to the Infinity basslink need all 4 speaker inputs to work correctly??? It is odd that the amp is a mono sub amp, but it does have 4 rca inputs?
#62
Yes you can tap into the wires before the sub amp. I have it that way on my car, and all that I want out of it is subs so it works great for me. If you are using a mono amp you don't need the 2 set's of RCA's. The signal coming out of the Bose amp into the sub amp I believe is crossed over already so you don't even need any real processing power. If you are running full range speakers than yes, you do need to get the signal else were.
#63
I have the B(l)ose system and I haven't seen anyone discuss a way to reduce the muddy sound of the system. Just adding a sub will increase base, but by not removing some from the front speakers simultaneously, it will just be muddy with more bass! Can anyone point me in the direction of a wiring harness that will allow me to tap the signal before the B(l)ose amps, run it into a JL 500/1 amp where I can crossover the sub frequencies, and then go back into the B(l)ose amp? I would like to do this using wiring harnesses to minimize or eliminate cutting...is this possible????
Lee
Lee
#64
Lee
Lee
#65
Thats complete nonsense. The 4 inputs are only there in case you have a system that doesn't have a dedicated non fading sub output. If you don't then you can either hook up all four channels so that you won't lose any sub on fading front or back or you can just put 2 channels of input (front or rear) and then just have to deal with losing sob out put with fade.
#67
I have not personally worked with this amp, but when looking at the litterature, it does not indicate that. If that is the case, then two Y cables (one for each signal) will give you four outputs. Can you clarify what the "resonator" actually is? Maybe I am missing something here.
#68
#69
Where did you run your power wire at?
Nevermind I found a nice place to run it. It was a pain but it works. Now i need to hook up my amp. Hopefully I get the right wires to draw a signal for my amp
#71
I didn't cut any wires, i just tapped into them w/ scotchlock taps, and tapped the ones going into the bose amp.. the car's system seems to use a very low preamp voltage, so that's why i used all 4.. fyi, i'm using a basslink II and mine sounds good and has plenty of output
#73
for a traditional line out converter, you would tap into the rear right (2) speaker wires and the rear left (2) speaker wires.
