How does one removed saved locations?
I've accidentally marked a lot of random places around my house when I was messing with my Nav a few weeks ago and it's really bothering me now.. I can't seem to remove the numbers from my 'Address Book' now nor can I find it anywhere to even delete other locations. Can't seem to find my Manual since I took it out to install subs, can someone let me know how to get rid of these things. Thanks.
DGC
DGC
From map:
Set crosshairs over the stored location, hit enter, select Delete, confirm.
From menu:
Setting=>Navigation=>Address Book=>Stored Location
Pick an item, hit enter, select Delete, confirm.
Instead of selecting Stored Location above you can also run down to 'Delete Stored Items' and delete things like home location, *all* stored locations/routes/tracking/etc.
Tony
From menu:
Tony
If the car isn't moving I think you can use the button marked Slow on the touchscreen for small movements of the crosshair, not sure if you tried that. Glad to hear that the menu option worked for you.
Tony
Tony
