Hard Drive Mod
Old 10-14-2016, 04:06 PM
  #136
JSolo
Just say no!!!!!
JSolo's Avatar
I'm surprised cars as new the '14 are still using a mechanical drive. Flash memory has proven to be quite reliable. Also stored data doesn't get changed too often.
Old 10-14-2016, 05:37 PM
  #137
kiseliok
G37 Community Team
kiseliok's Avatar
Also expensive back when these headunits were originally built. If these were "redesigned" in 09, then they probably finalized the design around 07? That's close to 10 years ago. Flash memory was far from mainstream.
Old 10-15-2016, 08:39 AM
  #138
djdiskino
djdiskino's Avatar
I'm wondering since I have a non-Nav unit if I can use the Nav unit image and maybe get the updated GUI that you guys have. I know the nav function won't work which is totally fine. I think the screen resolutions between the two models are different however.
Old 10-15-2016, 11:06 AM
  #139
Elco
Elco's Avatar
Ok. I have some good news and some bad news...
Good news:
After 30 minutes and 60$ spent, i got the US spec unit HDD unlocked and i made a image from it.
The G37x US version HDD image with 2012 navigation version on it is available HERE
Bad news:
The US spec unit don't work with SSD.
I use a KingSpec IDE SSD.
The same SSD that work's just fine on EU unit, don't work on US unit.
The unit hang on INFINITI logo for a minute, then enter safe mode with no media display, only AC display and only volume **** working on the unit.
I found a similar problem on BMW forums: DIY Upgrade Navigation CIC Hard Drive to SSD Solid State Drive - Bimmerfest - BMW Forums
where users are upgrading to SSD and they found that on BMW unit, that use the same QNX OS like Infiniti, they can use only some "cheapo" "Zheino" SSD. They tested with some other expensive SSD and they didn't work.
Maybe that Zheino SSD is the solution for US G37 unit.
kiseliok (10-15-2016)
Old 10-15-2016, 11:07 AM
  #140
Elco
Elco's Avatar
If you have the Music Box option, then your unit have HDD inside.
If no Music Box option, then your unit don't have HDD.
Old 10-16-2016, 06:16 AM
  #141
Elco
Elco's Avatar
did anyone got the US HDD image i posted above?
Old 10-16-2016, 06:30 AM
  #142
White_2013_G37x
White_2013_G37x's Avatar
Yes I did.
Old 10-16-2016, 06:38 AM
  #143
Elco
Elco's Avatar
I just checked the navigation module... i might be able to read the firmware from module flash.
But i don't know if that will help anyone...
I am still puzzled why the US unit don't work with my SSD...
It must be some difference on firmware and how it handle the HDD parameters.
Old 10-16-2016, 03:21 PM
  #144
jpowersjr2
jpowersjr2's Avatar
You'll figure something out Elco! I have faith!
Old 10-17-2016, 06:49 AM
  #145
Elco
Elco's Avatar
Well... i bought this US unit initially to replace my EU unit because the HDD on my EU unit was acting up.
Since i managed to replace the HDD on my EU unit with a SSD, i don't need this US unit anymore... and now, is only a fun project...
atasav (03-25-2024)
Old 10-17-2016, 06:58 AM
  #146
djdiskino
djdiskino's Avatar
Going to grab this today hopefully! Thanks for hosting! You the real MVP!
Hoping I can find an ssd that works with the image and play around with the files. I definitely want to try and re-skin the UI.
Old 10-17-2016, 07:26 AM
  #147
Crazyirish
Crazyirish's Avatar
Factory setup is native IDE/ATA. SSDs are not natively supported by this standard. The SSD has to have a built in controller to convert it to IDE. These are built into the hard drive of course, but standards seem to vary a bit. Upgrading older PCs (that are also natively IDE) to an SSD is a similiar hit or miss situation. Some POST but wont boot, some hang in booting, and some wont even POST.
Old 10-17-2016, 03:48 PM
  #148
White_2013_G37x
USA version of the NAV.
I found the Nissan password for the Hard Disk in the APP.BIN file today. Here is the line with the information. It also includes a hard drive Identify line looking for Hitachi or Toshiba drives, this might be why the US version won't boot with the SSD. Still researching.
Error [%s] Invalid parameter.(flg=%d)
ataHddUnlockSecurity Error [%s] Password Missmatch.(flg=%d,errno=%x)
ataHddSetPassword 0X642-951-03X0 XXNAVAXI Error [%s] Set Password.(flg=%d,errno=%x)
ataHddDisablePassword Error [%s] Invalid parameter.(status=%x)
ataHddGetSecurityStatus Error [%s] Read Identify.
ataHddReadIdentify HITACHI HE Hitachi TOSHIBA Error [%s] Invalid parameter.(temp=%x)
ataHddTempGet Error [%s] Invalid Hdd Model.(hdd=%d)
Error [%s] Get Temperature.
Error [%s] Flush Cache.
ataHddStopAccess Error [%s] Idle Immediate.
ataHddStartAccess Error [%s] Invalid parameter.(data=%x)
ataHddswapByte Error [%s] Invalid parameter.(size=%d)
40-652-93100 AXANIV Error [%s] Invalid Passsword ID Input.(flg=%x)
ataHddPasswordCheck Error [%s] HDD Access.
Error [%s] Security Status Get[1].
Error [%s] HDD Cache Flush.
Error [%s] HDD Connect.
Error [%s] Driver Init.
Error [%s] Security Unlock.
Error [%s] Security Status Get[2].
Error [%s] HDD Security Disabele.(status=0x%04X)
HDD Unlock %s [Used Password:%s]
Failed Successed MASTER USER
########## ATA INFORMATION ########
ATA BlkDev [Null]
ATA BlkDev [0x%08x]
HDD Model [%d]
Serial [%.20s]
Rivision [%.8s]
Model [%.40s]
Sectors [%10d]
Enable Set1 [0x%04x]
Sequrity [0x%04x]
----- ATA READ/WRITE INFOMATION -----
Old 10-17-2016, 04:00 PM
  #149
kiseliok
G37 Community Team
kiseliok's Avatar
What are you using to get this info?
Old 10-17-2016, 04:19 PM
  #150
White_2013_G37x
DiskInternals Linux Reader. Location: Volume 1, X9U, App, APP.BIN
Endoding: ANSI (Windows) Mode: Text
kiseliok (10-17-2016)
Quick Reply: Hard Drive Mod
