HELP !! Car won't start......
yeah there shouldnt be any problem with doing a simple install or any stereo install with this car i had mine done with help of my shop and had no issues basic setup like anyother car out there so those in worry mode dont be its not a major issue its most likely a one off problem
actually it makes sense... everytime u disconnect the battery and reconnect you have a chance that you could blow fuses and probably what happened to you was when installing the system you reconnected the battery and blew a fuse plus you probably didnt secure the connection with the battery. also could be a theft control device on the G37.
i post this somewhere else but it could obtain to you...
The end of the story....It was a fuse in the fuse block which is located next to the battery. How it happened?? Not sure. But a good one to put in your back pocket....so if everything works except for the engine gauges and the starter check this. Always Something!!
bikerjosh
08-19-2015 11:26 PM
KZK
Canada
08-11-2015 11:16 PM
