All about the Compact Flash Slot
#106
Super Moderator of Pwnage
I get my music from buy.com, and WalMart music online is also good (don't laugh they have a good selection). I listen to such a wide variety that I don't like buying whole CDs anymore. I like those sites because you can buy one song at a time without paying for a subscription service.
I just started using a CF. I have only put music from old CDs on it thus far however. They all work fine in MP3 mode
The only one's that I have had the problems with are the ones that I have downloaded. If I put them in "regular CD" format they will play, but if I change them to MP3 they wil not play on my car. But they will play in WMP.
It appears that it could be WMP that is the culprit. I am definitely going to buy and try Nero now and also perhaps try i-tunes.
#107
So this link http://www.infiniti.com/music-update/ says that you can update missing titles following the 3 simple steps. Only problem is that when you get to the 4th instruction of Step 1 "Select Search Missing Titles", that option is greyed out... unavailable.... anyone else seeing this as well? Any workaround?
#108
#109
If that were the case, I wouldn't have asked the question in the first place. I have loaded a couple of CD's to the music box that have no title/artist/album information and the option to "search missing titles" remains greyed out.
#111
So far I have tried it with a 256MB CF, a 4GB CF, tried it with the brake on/off, engine on/off, door open/closed.
I had a thought that perhaps the source CD had to be in the CD player in order to read the serial number of the disc, but that made no difference either. Totally stumped on this one.
Anyone have success making this work?
Edit: Forgot to mention, I even tried creating an "export.dat" file on the CF card to see if THAT might open up the option. FRUSTRATING!!!!
#112
Seeing as how the Aux Input to display video on the monitor is tied to the parking break, that seemed worth a try. Unfortunately, it makes no difference.
#113
So I completely removed the albums with no titles from the internal HDD, and started over, this time, going through the process of exporting missing titles immediately after each disc was recorded to the drive. It worked, but the downside is you're doing one CD at a time that way and the back and forth to the PC. Weird design.
#114
Almost every disc I own has been backed up using EAC. When I burn the backups I write CD-Text to the discs. The MusicBox has been picking up these titles without any problems, including the myriad of live recordings that have no Gracenote entries.
As far as the CF slot is concerned I've been finding it good for limited uses. Typically, I'll create "mix tapes" and set the slot to shuffle mode. Or, I'll dump a set of concerts to the card.
It would be nice if the CF reader in the G read playlists. That's one thing the bimmer's USB capability has. You can just plug in any old thumbdrive and go to town.
#115
#116
OK so I am back- new problem. I am using i-tunes and it downloads everything in MPEG4. How do you convert MPEG4 audio files to MP3. I bought software that is supposed to do it and it failed. grrrrr. So I can make a CD in regular audio format but I cant convert the MPEG4 to MP3.
I have literally tried for years to establish a setup so that I can just play my damn music that I legally bought and downloaded in an compressed format that will play on my cd player. I am tired of using whole CDs for only 14 or 15 songs.
sorry for the rant it is just frustrating. I was up late trying to figure out this stuff and downloading crappy freeware (SUPER) and then when I actually pay for something that is supposed to work (Xilisoft)it doesn't. It's only a computer right? I consider myself moderately savy. We should be able to make it do what we want it to do.... rant over...
#117
Sorry if you've done this already, but have you tried the steps described here? The comments have possible workarounds for protected files and some poeple have posted other possible conversion procedures and software. I saw a couple of potentially workable solutions there, like this site and this program, which has a 14 day free trial.
Good luck.
Tony
Good luck.
Tony
#119
