Help! My Bluetooth isn't working
So my Bluetooth works fine before I go to the store, but when I get out, it all of the sudden, doesn't work. My phone stayed in the car so I changed nothing, it just quit working. I tried to delete and re-pair it, but I can't do that either. I tried to pair another phone, but it won't let me do that. My phone says everything is fine and transmitting, but my car says that no phone is connected.
Any ideas?? I scoured the manual and found nothing. I think something is wrong with the car.
Also, does your caller ID show up on the nav screen when a call comes in? I swear my car quit doing that as well in the last few weeks.
Thanks for the help.
The caller ID only shows up if the name is stored in the car's phone book. As for your other problem, you might wanna take it to the dealer if all else fails.
this may sound dumb... but try:
1. erase pairing from your phone
2. shutting down bluetooth on the phone,
3. shutting the phone down
4. erase the pairing (you'll lose all stored numbers in the car if you have any)
5. turn off your car
6. wait a few seconds
7. turn your car and phone back on
8. turn bluetooth back on (on phone)
9. go through the pairing process again...
solved
The problem was due to a program called "Pocket Express" that was on my Blackberry. I don't use it anyways, so I erased it, but there is a patch that you can download to solve the problem as well.
more on bluetooth compatibility
I haven't been able to pair my cellphone with my G37. Dealer couldn't do it either. They told me to check the infiniti owners web site to see what phones are compatiable. My phone although it is new (and I upgraded to a new one from Verizon in order to have bluetooth) is not listed as being supported. Is there anything that I should be doing? Should I exchange the phone to one of the limited options available or wait to see if (and when) Infiditi adds my phone to the list. suggestions and info about blue tooth compatibility are appreciated.
Note that on the Infiniti website some phones are listed as compatible on vehicles with NAV but not without NAV. The 5300 is only good on no NAV cars. I got the 5300 and it works wonderfully and seamlessly in my car with no NAV. It also has a great home in my unused ash tray when driving!
bluetooth is a standard... and the different functions available to you depends on which version of that standard the phone and car implements...
with that being said... any bluetooth phone should be able to connect for a basic voice connection...
this doesn't mean you'll have access to more advanced functions.. like transfer of phone book, etc...
Try a different phone and see if that works. If it doesn't, it's either your car or you... (I know your sales guy tried too... but generally they cant find their a$$ with a light if they tried).
thanks -- nav versus no nav
thanks for your comments. I do like the clamshell type phone and the one you listed looks cool, but I do have navagation which is what I am trying to connect it to. Any one know why some bluetooth phones would work with the Navagation system and others don't? Or why some bluetooth phones don't work with the car? Isn't all bluetooth the same? thanks
Make sure you know what you're doing...
gammamotors
44
12-31-2015 12:48 AM
