bluetooth - download phone book
My uploaded contacts have "voice tags" and that is the easiest way for me to dial someone I know. Just say "phonebook" and she says "please say a number" and away you go. If you need to dial a number just say"dial" and when prompted spit out the number. I use the voice commands for everything and it all works terrific!
I can only upload one number at a time from my KRZR, so it's actually easier to just program them one by one with the input function and voicetag as opposed to uploading under Bluetooth.
i think the answer to your "contacts" problem is to use voice commands to access your contacts list.. just define a voice tag for each one that's important to you.. or all.. whatever. i have yet to find a voice command that can not get most of what i need done while in motion.. the more functions you can control via voice the better as i come from the camp you should be looking at the road... and no where else! all it takes is a split second to kill someone.. consider how much good your "contacts" list is going to do you in jail! I wont let this thread turn into a "motion" topic.. we can take that elsewhere.
With my Tytn, you can select all contacts and select beam (after setting your car to download the phonebook). On the phone menu you can then select where you want to send it to (it'll recognize the MY-CAR device). A few seconds later, the whole phonebook is transferred...
Well... where do I start? The stock rom in the phone does not have that feature enabled. However, the modified versions (at least some of them) do. If you don't know how to flash a new rom to your phone, I highly DO NOT recommend you start now because of this feature... you'll more than likely turn your phone into a nice expensive paperweight!!!
I've tried using a different phone (Sony Ericcson) to upload my contacts. And it worked. BUT each phone maintains a separate phone book, so I couldn't see the SE contacts when using my iPhone.
well that sucks! Even my e90 can transfer contacts over, i thought the japanesee would have that aswell. No worries though.
#29
I have my phone book uploaded into my car, but has anyone else found that their phone book is loaded weird. In my phone is lists my contacts by first name, but in the car is has them all listed by last name or the second word in the contact name. Does anyone know how I can change this so it is the same as it is in my phonebook? Thanks.
#30
You can find all of the bluetooth enabled phones that are compatible with the G here.
http://www.infiniti.com/bluetooth/ph...id=9&modelid=5
