| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#16 |
Team Outcast
Here is how +32 look like with stock camber(-1.8)
__________________
TEAM OUTCAST
Street Works Automotive Amplified Motorsports ~ Endless ~ Driveline Motoring ~ Iconz Wheel ~ Detailed Image ~ AJAutoDetail |
#17 | |
Quote:
Wheel offset is basically how far the [wheel mounting surface] from the centerline of the wheel as shown in the pic below ![]() If the offset is zero, it means the mounting surface is exactly in the center, to the right is positive and to the left is negative (negative offsets are not very common) For a fixed wheel design, decreasing offset forcefully increases the lip size.
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs | Debadged & Valenced | Painted Headlights Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Getting lost in this place? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#18 |
okay now I get it somehow...
One last question. at the rear if I order 20x10 30+ will increase the lip size more or the 20x10 32+ will increase the lup size more? which one of them will forcefully will increase the lip size? |
#19 |
depends on the rim your getting, if its a one piece then doubtful
__________________
AUTOKITS-X GRILLE l DIFFUSER l TS COILS l TS SIDES l TS BUMPER l MXP EXHAUST l SSR'S l HANKOOK'S l INJEN CAI l 3K HID FOGS l ICHIBA CAMBER l KICS R40'S l ILLUMINATED SILLS l BERK HFC l VLEDS l ALLIANCE 8/6 PISTON BBK |
#20 |
MYG37.COM Sponsor
im gonna chime in a bit since the specs for SSR is a bit confusing
fitment without being too agressive and no rubbing issue: 20x9 +31 (39mm = 1.5 inch lip) HP= high pad clearance for akebono 20x10 + 30 (65mm = 2.55 inch lip) NR = Normal Disk clearance If you don't mind a little more aggresive, i would run these with 245/35/30 and 275/30/20, maybe a 2 inch camber on the rear which is not too far off spec from OE (1.5 - 1.8 deg OE camber setting) 20x9.5 + 25(52mm = 2 inch lip) HP 20X10.5 + 30 (77mm = 3 inch lip) NR SSR Wheels - SSR Professor MS1 click on the 20's for the wheel chart Hope that helps, let me know if i can help ordering your wheels
__________________
www.amplifiedmotorsport.com Your One stop shop for your G37 needs. 323 8810882. Store hours: 11am to 8pm PST |
#21 |
Save yourself the headache and ask about the lip size before purchasing the wheel, some wheel brands have different spoke angles just to maintain the same lip size (concave wheels, convex wheels..)
__________________
#22 | |
Quote:
What a small world we live in you are just in myg37 and I didn't know it looolAnyway, FYI I have the stock breaks caliper of the G37S which is silver and written on it Infiniti. I haven't done any modification on the caliper or anything on the car yet. Do you have an example or any photos on these specs that you provided? 20x9 +31 (39mm = 1.5 inch lip) HP= high pad clearance for akebono 20x10 + 30 (65mm = 2.55 inch lip) NR = Normal Disk clearance I think I'll need to roll the fenders if I use these specs right? 20x9.5 + 25(52mm = 2 inch lip) HP 20X10.5 + 30 (77mm = 3 inch lip) NR For both specs do i have to do any modifications on the break calipers or any on the fender? I called them and they referred me to Lou@Amplified |
#23 |
definitely work with Lou for your wheels. He will take good care of you
__________________
08.BO.fully.loaded | Jasryl | Ventureshield | 8000K3000K | PIAA | Superbrightleds | BBGKv2 | FormulaOne | Bluebatmobile | Vizage | Burnout | Stillen | KWv3 | Volk | Yokohama | Kics | SPC F&R | HKS |
#24 | |
Quote:
To install front wheels do I have to modify the front breaks or anything? |
#25 |
MYG37.COM Sponsor
The OE non sport brakes are only a few mm smaller in width than the sport akebono's. They don't have a any other fitment that will fit better even with the non sport brakes in terms of the offset
__________________
#26 |
I'll take a photo of the front Brake just to confirm. I want to order the wheels and avoid getting something wrong..
#27 |
The OEM brakes are made by Akebono but painted and labeled infiniti
__________________
#28 |
don't think no more! order it from Lou@amplified
#29 | |
Quote:
I have checked SSR Wheels specs: SSR Wheels Wheel Lineup I can't find for the rear: 20x10 + 30 (65mm = 2.55 inch lip) NR I was able to find +37 if that what you mean and it was just a mistake. Is there any e-mail address for you in Amplified Motorsport that I can give to the shop in here so he can order the wheels for me through your shop? Please confirm the rear for me so I can order right away. Thanks man I owe you big time for your great help
#30 |
2009 Infiniti G37 |
Black Bird, why don't you just order them from Lou
__________________
09 G37 PG |Eibach Prokit|Ichiba spacers|GReddy SE|Injen SRI|VLEDS|AutoKits-X diffuser |
| Thread Tools | |
| Display Modes | |
