| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
G37X Coupe WHEEL OFFSET. WTF is it?
I have searches and searched and can't find the offset for a G37X coupe. Does ANYONE know what it is?
Best, Chris |
| Sponsored Links | ||
#2 |
Post whores must die!!
Did you look in the manual?
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Not knowing your way around? | Getting lost in this place? | Looking for factory manuals? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#3 |
Harmless Addiction
![]() My Garage |
If not in the manual, it might be like the wheels on the coupe where the offset is stamped on the back of the wheel.
__________________
G37S <--- Mod Details in 2008 Infiniti G37 Updated October 23, 2009 ______________________________ ![]() |
#4 |
Says in the manual..
__________________
09' G37x Coupe Tint/Spoiler/Debadged/3M/Eibach/Tinted Tails |
#5 |
anybody buy good aftermarket wheels for g37 xcoupe?
if so what and were they staggered? TPMS?..... |
#6 |
2009 Infiniti G37 |
I guess if you built your wheels, you could have a little staggered setup, the thing is all 4 tires need to be exact same size = no wide tires in back which sucks
If you get 1 piece wheels, no staggered setup
__________________
09 BS G37xCoupe |
#7 |
2009 Infiniti G37 |
20x9 255/35/20 all around is the size I have. Looks good, but when I go lower they might tuck a bit...
or maybe it's 20x9.5 I should probably know this
__________________
09 BS G37xCoupe |
#8 |
its +45 for the X. they use the same offset as the G37x Sedan. if you want to go aftermarket rims and want staggered rims make sure you stay within 3% of what the stock rims are. example you have 225/50/18 all around as stock rims. then you go ahead and buy rims that are 20x9.0 front and 20x10.0 rear the tires that will not mess with the AWD are in the range of 245/35/20 - 275/30/20 the AWD will not be affected because it is within 3 % of the stock rolling diameter.
#9 |
Gangsta...
It sounds like you might know the answer to the questions I posted in another string, so let me ask: I have a G37X and would like to put the S wheels on it. In order to use the same size all the way around, I would use four of the FRONT S wheels (19 x 8.5). Two questions:
1. Would that affect performance of the AWD? 2. Would it void any part of the warranty? Thanks in advance. |
#10 |
I THINK it was determined that we could run either all fronts or all rears for the regular g37 coupe on our x coupes but would need to double check. I am pretty sure their is a thread somewhere here on it but could not find it...
best, chris |
| Thread Tools | |
| Display Modes | |
