MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires > Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 09-30-2009, 08:12 AM   #1
350zrb
Trader Score: (0)
255/40R19 instead of 245/40R19?
Hi,
I know most people use 245/40R19 on OEM wheel in front.
But I am considering 255/40R19 in front.
Any pro of con of doing this?
Of course, I will stay with 275/35R19 in back.
Thanks
350zrb is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-30-2009, 08:33 AM   #2
wakeboardr116
___________
2008 Infiniti G37
Trader Score: (4)
IMO I'd just go with the 245's. 255/40 will have a larger diameter than the 245s. Ideally you want to keep the diameter as close to the stocks as possible and 245/40 is as close as you can get.
wakeboardr116 is offline   Reply With Quote
Old 09-30-2009, 09:41 AM   #3
shumby
shumby's Avatar
Trader Score: (1)
Send a message via AIM to shumby Send a message via MSN to shumby Send a message via Skype™ to shumby
why not a 285 in the back?
shumby is offline   Reply With Quote
Old 09-30-2009, 11:37 AM   #4
g37rider
2008 Infiniti G37
Trader Score: (3)
I run 255/40/19. Wider look and better handling.
__________________
'08 G37 | HKS Air Filters | Tanabe: Sustec Pro S-0C, Y-Pipe, Medalion | 19" Volk G10s
g37rider is offline   Reply With Quote
Old 09-30-2009, 03:42 PM   #5
350zrb
Trader Score: (0)
Quote:
Because I think that 275 on 19x9 is already pushing it?
275 mm on 9 " seem a lot already.
On the other hand
245 mm on 8.5" still have room for 255 mm.
Old 09-30-2009, 03:43 PM   #6
350zrb
Trader Score: (0)
Quote:
In front on OEM wheel?
Any rubbing?
Old 09-30-2009, 04:40 PM   #7
g37rider
2008 Infiniti G37
Trader Score: (3)
No rubbing on an aftermarket 19x9.5 wheel. 255 will surely fit the 19x8.5 wheel.
Quote:
Any rubbing?
__________________
Old 09-30-2009, 05:00 PM   #8
Xcalibur
Go Heat!
2008 Infiniti G37
Xcalibur's Avatar
Trader Score: (1)
255 is the tire Width and yes it will fit on the stock rims.
40 is your tires aspect ratio. I would stay 45 in front on those 19s. If your not dropped the last thing you need is a lower profile tire! That gap will be out of control!
__________________
X©alibūr» 2008 G37S - 6MT| Kicker | Stillen | Eibach | SPL | XIX | VOLK | Vredestein | SportWing | PIAA | V-LEDS | BERK |
Xcalibur is offline   Reply With Quote
Old 09-30-2009, 05:18 PM   #9
Loi
Trader Score: (0)
Send a message via AIM to Loi
255/40 on the front is possible, but it will look too "beefy" and there may be rubbing issue.
__________________
2008 IP G37S 5AT - Volks SF-Challenge
Loi is offline   Reply With Quote
Old 09-30-2009, 06:00 PM   #10
g37rider
2008 Infiniti G37
Trader Score: (3)
There's no way 40s on 19s look too beefy, unless you like the look of a bead of rubber on your rims. No rubbing issues for me and I'm dropped.
Quote:
__________________
Old 09-30-2009, 08:52 PM   #11
greggv
Trader Score: (0)
I had 255x40 on my stock front wheels and had no problems. Changed to Iforged, now I've got 245x40 in the front. Same difference. 10 mm is only about 1/4 inch. Can you tell that from a distance? Use whatever size you want.
__________________
Eibach springs, Magnaflo exhaust, iForged wheels, and Vredestein tires
greggv is offline   Reply With Quote
Old 10-01-2009, 12:58 AM   #12
dxxd
Trader Score: (0)
wakeboardr116--IMO I'd just go with the 245's. 255/40 will have a larger diameter than the 245s. Ideally you want to keep the diameter as close to the stocks as possible and 245/40 is as close as you can get.
Diameter of OEM fronts, 225/45-19, is 26.97 inches. Diameter of 245/40-19 is 26.71 inches and diameter of 255/40-19 is 27.03 inches. So 255/40-19, not 245/40-19, is as close as you can get!
dxxd is offline   Reply With Quote
Old 10-01-2009, 09:25 AM   #13
350zrb
Trader Score: (0)
Diameter of OEM fronts, 225/45-19, is 26.97 inches. Diameter of 245/40-19 is 26.71 inches and diameter of 255/40-19 is 27.03 inches. So 255/40-19, not 245/40-19, is as close as you can get![/quote]
I agree with 255/40/19 is closer to 225/45/19 than 245/40/19.
This is why I am thinking about 255 instead of 245.
I think the reason most people use 245 in front because they move 245 from the back and use them in front?
Old 10-01-2009, 01:50 PM   #14
HamstersG
Harmless Addiction
2008 Infiniti G37
HamstersG's Avatar
Trader Score: (3)
I struggled with all the variables as well. Here is a post with some data that may be useful.
http://myg37.com/forums/wheels-and-t...ize-table.html
Hi,
Thanks
__________________
G37S
<--- Mod Details in 2008 Infiniti G37
______________________________
HamstersG is offline   Reply With Quote
Old 10-01-2009, 02:00 PM   #15
350zrb
Trader Score: (0)
So, what do you end up using in the front?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
