Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires > Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 08-26-2009, 02:08 PM   #1
Renegar
Trader Score: (0)
Hankook Ventus V12 Evo K110 (Report)
I replaced the stock RE050A's with Hankook Ventus V12 Evo K110's. I got 20,300 miles out of the RE050A's.
My intent with this thread is to provide periodic updates on how the tires are doing as I put miles on them.
First thing to note is that I put 245/40-19's on the front and 275/35-19's on the back. Car came with 225/45-19's in the front and 245/40-19's in the back.
For those that don't already know, this is what is called a "+0" size. It is nearly the same rolling diameter as the stock tires so the speedometer is only off by 0.4 MPH. I personally could not tell a difference probably because the new tires have more tread and may actually have a larger diameter than the worn out ones they replaced.
I'm also using the stock rims. These larger tires fill out the wide factory wheel very well. Looks like the larger size belongs on these rims to me.
Also, there is absolutely no rubbing or clearance issues.
When compared to the stock Bridgestones the first thing I noticed was the reduced noise. They are quieter for sure.
The second thing I noticed is that they actually ride a little better even though they are wider. Sharp impacts feel like a road crew came out and rounded off the edges of all the bumps and potholes. I attribute this to the softer sidewall noted in comment #3 below.
Third thing is the turn-in. I realize these are not yet broken in but the turn-in reponse is much faster. Feels as though the steering ratio went up when it obviously did not, but thats how it feels. However, I've noticed a softer sidewall. The tire is definately not as "direct" as the RE050A. I noticed that when I tried a fast lane change type move that I could feel the rear end playing "catch up" after settling back into a lane. Once out of the car, I noticed the flexing sidewalls after I shook the rear end side to side. The RE050A's barely moved when I did this with them. I'll have to get used to the softer less direct feel, but keep that in mind if you like the immediate direct responses the RE050A's provide.
_______________________________
I've added some photos below. For larger sizes head over to my gallery "http://myg37.com/forums/members/rene...12-photos.html"
I will come back and provide updates to things such as dry grip, wet grip, noise over time, MPG changes, etc.
Drop a question and I'll be happy to answer regarding my experience with the Hankook Ventus V12 Evo K110's.
__________________
Red 2008 Infiniti G37 6MT Coupe
Last edited by Renegar; 08-27-2009 at 12:00 PM. Reason: Updated Initial Comments + Added Photos
Renegar is online now   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-26-2009, 02:17 PM   #2
jran76
Trader Score: (0)
I've heard really good things about these tires, especially for the price. I will be curious to see how the hold up.
__________________
09 G37S Sedan-Liquid Platinum-6MT-Volk GTS wheels-Eibach suspension-Cobb AP
jran76 is offline   Reply With Quote
Old 08-26-2009, 07:03 PM   #3
Foresite
Trader Score: (0)
I need to get new tires. Do you have stock rims and are those sizes larger than OEM tires?
Foresite is offline   Reply With Quote
Old 08-26-2009, 08:47 PM   #4
Staples
Trader Score: (1)
Quote:
They're both bigger and wider. The stock sizes are 225 in the front and 245 in the rear. He's running 245 in the front and 275 in the rear.
Yes he also is on stock rims. I'm thinking about doing this rather then going to wheel spacers since I've heard a bunch of complaints with vibration on the road.
These are also so much cheaper then our stock Potenzas. Keep this thread updated because I'm seriously considering getting these in the near future.
__________________
'08 Infiniti G37s - 35% Tint, Not Stock!
Staples is offline   Reply With Quote
Old 08-26-2009, 09:48 PM   #5
swordsman54
Trader Score: (0)
Send a message via AIM to swordsman54
Thanks for doing this. I am also seriously considering these tires in the near future in the same sizes.
swordsman54 is offline   Reply With Quote
Old 08-26-2009, 11:44 PM   #6
TicketProof
TicketProof's Avatar
Trader Score: (0)
Could u possibly take some pics of the tires on the car so I could see how much more they stick out ? Thanks
__________________
08 G37S l PG l G l Nav l Prem l spoiler l illum. kickplates l Stillen Gen.3 CAI l MXP Catback l BBGK v2 l LED swap l Stillen sways l Eibach Pro-Kit | GT Spec SB l HPA 6000k HID's l Flat black grill
TicketProof is offline   Reply With Quote
Old 08-27-2009, 12:58 AM   #7
Staples
Trader Score: (1)
Quote:
+1 you beat me to it
__________________
Old 08-27-2009, 11:59 AM   #8
Renegar
Trader Score: (0)
Done. See original post again for update.
__________________
Old 08-27-2009, 01:31 PM   #9
Foresite
Trader Score: (0)
Just so I am absolutely clear on the issue. If you put the larger size tires on the OEM rims is there any downside.
1. Do you have to buy anything extra?
2 Do you have to do anything to the G? (Raise it / lower it?)
3. Does it rub anywhere?
I want to do this but I want to make sure I understand any possible issues before I do. Thanks.
Old 08-27-2009, 03:36 PM   #10
notalk
Trader Score: (0)
Quote:
Sometimes tire pressure adjustments can improve this feel. Sometimes, "tweaking" alignment settings can also help.
My V12's just came in and I expect to have them mounted this Saturday. I will follow your thread and see if I can add anything.
With the RE050's, I had to bump up the front pressures 1 lb (to 36) to get the turn in feel I was looking for. Maybe the V12's need a little more pressure in the rears. I guess I will start with 35 all around and play from there.
Keep in mind you'll need anywhere from 100 miles to 200 miles of driving to wear off the tread coating. So, no hard cornering, stopping or starting during this time. And, because it takes some driving time to get a feel for pressure changes over your "normal" driving routes, it may take a while playing with pressure changes before you find a happy setting. I also figured I would re-align after about 1,000 miles (thanks, Firestone, for the lifetime alignments).
I am anxious to follow your comments, and see if I can add anything to this thread. Thanks for starting it.
notalk is offline   Reply With Quote
Old 08-28-2009, 01:24 PM   #11
Renegar
Trader Score: (0)
Quote:
Sounds great.
I got the Firestone lifetime alignments too. Pretty good deal.
Funny you should mention the miles it takes to wear off the coating. I have always wondered how long it takes.
Even though I've only got about 130 miles on them, yesterday it rained like mad and I noticed they were terrible in the rain...slidding very easily. I sure hope thats only because they are still so new. I will report on how they handle in the rain after I've got quite a lot more miles on them. I don't want to judge them too soon.
__________________
Old 08-30-2009, 01:16 AM   #12
Renegar
Trader Score: (0)
Anyone know if we should be running more than 35psi in the wider size tires?
__________________
Old 08-31-2009, 01:53 AM   #13
TJHG37S
LA G Club
TJHG37S's Avatar
Trader Score: (7)
Send a message via AIM to TJHG37S
I have these in 245/35/20 and 275/30/20 and love them, don't have the wet slipping issue you had so chalk that up to new tires?
__________________
08 G37S VR/Graphite - Team LA:G's | Los Angeles G's (Infiniti G37)
TJHG37S is offline   Reply With Quote
Old 08-31-2009, 09:03 PM   #14
Staples
Trader Score: (1)
Just ordered these today, couldn't beat the price shipped either!
__________________
Old 09-01-2009, 02:25 AM   #15
Renegar
Trader Score: (0)
I'll be trying 38psi this week.
As usual, I'll report back if it helped with anything.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
