Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires > Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 04-14-2009, 11:37 PM   #1
G37Sam
Post whores must die!!
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Send a message via MSN to G37Sam
Upgraded to FR:245/40 & RR:275/35
Tires needed to be changed that's no joke, you must've seen what they looked like from my other AutoX thread. I got a good deal on Nitto N555 and bearing in mind the nature of my driving, I wouldn't want to spend any more on tires.
So I pulled the trigger on them, 245/40 & 275/35. To those who can't read my signature I'm still on stock wheels, dropped on Eibachs with 20mm spacers.
They fit fine. When I'm angling on speed bumps no rubbing issues however, (here's the sad part) My rear tires rub against the fendor when I drive over dips. I'm really concerned about rubbing on corners due to body roll. And no, coilovers aren't coming anytime soon. Maybe strut & aftermarket swaybars would help.
Anyone tried fendor rolling?
I'll post pix once when I get her cleaned. It rained right after the tires install.
G37Sam is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-14-2009, 11:40 PM   #2
Stoof@180Custom
MYG37.COM Sponsor
2008 Infiniti G37
Stoof@180Custom's Avatar
Trader Score: (1)
The fenders are pre-rolled from the factory.
Are you sure theyre rubbing the fenders and not the liner on the inside?
__________________
G37NYC~180°~Iforged~Mastergrade~Seibon~Injen~Berk~ HKS~JIC~Hotchkis~GTSpec~Stoptech~
Stoof@180Custom is offline   Reply With Quote
Old 04-14-2009, 11:42 PM   #3
Saints Go Marching In!
2008 Infiniti G37
Trader Score: (19)
Take off the spacers in the rear, get smaller ones, or get a rear camber kit.
__________________
Get your custom grounding kits at
Black Betty is offline   Reply With Quote
Old 04-14-2009, 11:42 PM   #4
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
It's my guess, I was running perfectly fine with 245s in the rear
Old 04-14-2009, 11:45 PM   #5
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Quote:
hmmm..
smaller spacers = no more flush look
camber kit = more tire wear
Old 04-14-2009, 11:49 PM   #6
xlack
NorCaL G!
xlack's Avatar
Trader Score: (1)
Send a message via AIM to xlack
why is camber kit = more tire wear?
xlack is online now   Reply With Quote
Old 04-14-2009, 11:51 PM   #7
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Quote:
because I'll be increasing my camber (which is already like -2deg) to avoid the rubbing = uneven wear!
Old 04-14-2009, 11:52 PM   #8
Kidcane
Florida G Club
2008 Infiniti G37
Kidcane's Avatar
Trader Score: (4)
Just figure out where it is rubbing, probably the liner, and trim it or remove it.
__________________
Ruining threads since 2003
Kidcane is offline   Reply With Quote
Old 04-15-2009, 07:39 AM   #10
WhosUrBuddiee
Trader Score: (0)
Get a paint pen or whiteout. Do a line across your tire, drive around, check where the paint/whiteout is missing from. You found where you are rubbing.
Hopefully it is just the lining, if not, you are going to have to get a smaller spacer or new tires.
__________________
G37S | Vibrant Red | Bone Stock |
WhosUrBuddiee is offline   Reply With Quote
Old 04-15-2009, 09:19 AM   #11
elite
Trader Score: (1)
^ listen to your buddiee
elite is offline   Reply With Quote
Old 04-15-2009, 08:44 PM   #12
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Yup, I think its just the lining.. Should I just cut it out?
Old 04-15-2009, 08:51 PM   #13
WhosUrBuddiee
Trader Score: (0)
You can either find the exact spot it is rubbing and cut out that area or remove the pop tabs and take out the whole lining. I believe it is actually 2 or 3 sections.
__________________
Old 04-15-2009, 08:55 PM   #14
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
hmmm tomorrow is going to be fun I suppose!
Old 04-15-2009, 10:49 PM   #15
w0ady
w0ady's Avatar
Trader Score: (1)
Send a message via AIM to w0ady Send a message via Yahoo to w0ady
hm i just posted in your auto-x thread and i see that was with the stock tires. im thinking about 15mm spacers all around since i have the same tire sizes as these.
__________________
09 athens 7at g37s coupe 12/22/08; 05 athens 5at g35 coupe r.i.p. 5/13/05-10/29/08
w0ady is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
