Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires > Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 03-09-2009, 03:25 PM   #31
xlack
NorCaL G!
xlack's Avatar
Trader Score: (1)
Send a message via AIM to xlack
sorry if this has been posted but will 255/30/20 rub in the fronts?
xlack is offline   Reply With Quote
Old 03-09-2009, 04:53 PM   #32
Saints Go Marching In!
2008 Infiniti G37
Trader Score: (19)
Quote:
Not many folks running a 30 series tire in front. One that I noticed here reported no rubbing.
__________________
Get your custom grounding kits at
Black Betty is offline   Reply With Quote
Old 03-09-2009, 05:06 PM   #33
silent06
Trader Score: (0)
Quote:
Originally Posted by Black Betty View Post
Added a link in 1st post to a useful wheel offset calculator.
Hey BB- I started to post a offset calculator in this thread, but didn't want spam it up, as it is for reference. Below is a link to the calculator I use. It provides a good degree of detail and depiction that may curb some of the repetitive offset and tire questions. Have a look.
http://www.bigcustomwheels.com/rt_specs.jsp
silent06 is offline   Reply With Quote
Old 03-09-2009, 05:15 PM   #34
2008 Infiniti G37
Trader Score: (19)
This one is much better than the one I posted in the first post. Changing it to this one now. Thanks!
__________________
Old 03-16-2009, 07:04 AM   #35
Ivoidwarranties
It's HER car.
2008 Infiniti G37
Ivoidwarranties's Avatar
Trader Score: (2)
Here's a little more useful info:
225/45-19
Section Width: 8.85" or 225 mm
Overall Diameter: 26.97" or 685.03 mm
Sidewall Height: 3.98" or 101.09 mm
Circumference: 84.72" or 2151.8 mm
Revs per mile: 771.2
245/40-19
Section Width: 9.64" or 245 mm
Overall Diameter: 26.71" or 678.43 mm
Sidewall Height: 3.85" or 97.79 mm
Circumference: 83.91" or 2131.3 mm
Revs per mile: 778.7
Ivoidwarranties is online now   Reply With Quote
Old 03-16-2009, 10:48 AM   #36
G37Sam
Post whores must die!!
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Send a message via MSN to G37Sam
Great thread BB!
wonder if I'd rub with 275's and 20mm spacers in the rear.. where's the ruler when you need it!
G37Sam is online now   Reply With Quote
Old 03-28-2009, 06:48 PM   #37
ratso000
2008 Infiniti G37
Trader Score: (0)
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Wheel offset calculator
Does anyone know what optional tire sizes will fit the stock 18' wheels on the front of 2008 stock g37 journey? Tire rack only shows the oem size 225 50 18 as being able to fit the front with oem 18' weels. Any information would be helpful ratso000
ratso000 is online now   Reply With Quote
Old 04-06-2009, 01:45 AM   #38
All_G
Trader Score: (0)
Great info! Thank you all for posting it.
__________________
2008 G37S - Athens Blue / Stone – Premium Pkg / Spoiler
All_G is offline   Reply With Quote
Old 06-13-2009, 11:12 AM   #39
prostho
Trader Score: (0)
upsize tires for g37x sedan 17"
Want to change oem goodyear rsa to Michelin Pilot Plus.
Goodyear RSA's awful for any aggressive driving. Stock size 225/55/17. Would like to upsize to 245/50/17.
Revolution per mile numbers are close but I am concerned about the possibility of rubbing. Any advice would be appreciated.
2009 Black G37x premium package 7at
prostho is offline   Reply With Quote
Old 08-06-2009, 04:13 PM   #40
ctc0503
Trader Score: (0)
tire wear
I just put 22K on mine and are nearly bald. What is the typical mileage on the stock 19s (front and rear) before they are due for replacement?
I am thinking I have 5k left on mine at best.
Thanks!
ctc0503 is offline   Reply With Quote
Old 08-07-2009, 09:54 AM   #41
JhonnyboyNYC
2008 Infiniti G37
Trader Score: (0)
hey guyz quick question? if i buy a set of wheels 19x8.5 with the offset of 35mm will i have to buy spacers for it? and will it be good for the ride?
JhonnyboyNYC is offline   Reply With Quote
Old 08-07-2009, 03:37 PM   #42
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Have to buy? Of course not, but if you want it to flush you might need like 10-15mm ones
Old 09-16-2009, 06:09 PM   #43
BHCubed
Trader Score: (0)
Thanks!
I'm in the same boat, and was wondering this myself.
__________________
08 G37 Journey/Premium/Sport AT/Athens Blue/Stone
BHCubed is offline   Reply With Quote
Old 10-27-2009, 05:49 AM   #44
B L U E S L A T E
Trader Score: (0)
Needed this info as well. Thanks BB for sharing.
__________________
Check yourself.
B L U E S L A T E is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
