[TSB] G37 Oil consumption ITB10-048
Hello Everyone,
Here is a fairly recent TSB for oil consumption on the VQ37VHR.
I have the 8 page PDF but I am not able to upload it. The upload tool will not let me even though it is under the max size requirement. In the meantime:
Edit: Here is a link to the PDF: http://www.infinitig37.com/TSB/1SY30.pdf
Classif ication: Reference: Date:
EM10-006 ITB10-048 July 30, 2010
2008 – 2010 G37; ENGINE OIL LEVEL IS LOW
APPLIED 2009 - 2010 G37 Sedan (V36)
VEHICLES: 2008 - 2010 G37 Coupe (CV36)
2009 - 2010 G37 Convertible (HV36)
APPLIED
VQ37VHR ONLY
ENGINE:
2008-2009 G37 Coupe\Sedan & 2009 Convertible: All
APPLIED VIN /
DATE: 2010 G37 Coupe vehicles built from:
JN1CV6EK(*)AM100001 to JN1CV6EK(*)AM102428 up to 05-Apr-2010
JN1CV6EL(*)AM150001 to JN1CV6EL(*)AM152039 up to 05-Apr-2010
2010 G37 Sedan vehicles built from:
JN1CV6AP(*)AM200001 to JN1CV6AP(*)AM202365 up to 02-Apr-2010
JN1CV6AR(*)AM250001 to JN1CV6AR(*)AM252477 up to 02-Apr-2010
JN1CV6AP(*)AM400001 to JN1CV6AP(*)AM406683 up to 05-Apr-2010
JN1CV6AR(*)AM450001 to JN1CV6AR(*)AM458374 up to 05-Apr-2010
2010 G37 Convertible vehicles built from:
Automatic Transmission equipped:
JN1CV6FE(*)AM351001 to JN1CV6FE(*)AM351532 up to 05-Apr-2010
JN1CV6FE(*)AM350001 to JN1CV6FE(*)AM350542 up to 18-Dec-2009
Manual Transmission equipped:
JN1CV6FE(*)AM351001 to JN1CV6FE(*)AM351899 up to 06-Apr-2010
JN1CV6FE(*)AM350001 to JN1CV6FE(*)AM350749 up to 12-Jan-2010
IF YOU CONFIRM
Engine oil level is low OR there is unusual engine noise.
ACTION
Use the “Repair Flow Chart” in the Service Procedure on page 2 to determine the complete repair procedures
for a specific vehicle.
CAUTION: If the short engine is replaced as part of this bulletin, please advise the customer to follow
the Owner’s Manual Engine “Break-in Schedule” for the first 1,200 miles including:
• DO NOT RUN THE ENGINE OVER 4,000 RPM.
• DO NOT ACCELERATE AT FULL THROTTLE.
NOTE: Check OBD-II “Engine” Self Diagnosis for any stored DTC codes and use the appropriate Electronic
Service Manual (ESM) to repair any DTC code found stored.
Infiniti Bulletins are intended for use by qualified technicians, not 'do-it-yourselfers'. Qualified technicians are properly trained
individuals who have the equipment, tools, safety instruction, and know-how to do a job properly and safely. NOTE: If you believe
that a described condition may apply to a particular vehicle, DO NOT assume that it does. See your Infiniti dealer to determine if this
applies to your vehicle.
APPLIED
VQ37VHR ONLY
ENGINE:
APPLIED VIN /
IF YOU CONFIRM
ACTION
Haven't heard much about this yet, hopefully we don't hear too much about it.
I found my oil to be about in between the H and L on the dip stick at the time of my current oil change after 6000kms (3750mi)
I bought a 2010 sedan end of March.
Took it on a trip of 4,000 miles when the car was only 1-1/2 months old and had 2,000 miles on it. My first oil change was at 6,000 miles. The oil was still at the full mark on the dip stick, at that time, so apparently I don't have an oil consumption problem.
I have had zero problems with the car to date.
Agreed, we haven't seen really any issues with oil consumption. My dipstick stays in-between low and high when it's time for my oil change interval. It's not out of the ordinary to see your oil levels not at the full mark being a lot of it sits on the head, and all cars burn some amount of oil.
You would think they would have fully fixed this issue by now with the HR motors, and now the VHR.
This is a great few paragraph article I read;
"Now a word about new cars. People notice the engine in their new vehicle seems to be burning oil. They contact the dealer and are advised that using oil is a "normal condition." I agree, however there is a difference between "burning oil" and "using oil." We just discussed how oil is burned. In contrast, today's engines operate at higher temperatures and compression ratios, causing oil to be used. Higher temperatures and compression ratios achieve two things:
1.
Lower exhaust emissions
2.
More power out of smaller engines
However, along with these benefits comes the side effect of using oil, due to the increased friction and heat. As a result, the oil is evaporating or being broken down while doing its job. In other words, the oil is being used. It is not going out the tail pipe as it does when it is burned.
The rate of oil use depends on how much the vehicle is used and, more importantly, under what load. For instance, a 3/4-ton pickup truck used for hauling will use more oil than a small passenger car. For those experiencing a higher rate of oil use, I suggest using synthetic oil. It has a higher resistance-to-viscosity breakdown and will do a better job than standard oil."
It kind of makes sense though, are cars are using 11:1 compression which is fairly high ratio which causes more oil evaporate.
1.
2.
i have an 09 coupe and since mid summer have undergone an "oil consumption test/record" . i would have less than a 1/4 of oil left (dipstick) at 6000km oil change intervals. just got a call today from dealership....new motor on order.
09 g37s coupe mt
35000 kms
used ester oil from day one.
09 g37s coupe mt
35000 kms
