MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > TSB - Technical Bulletins
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 03-27-2009, 10:58 PM   #1
Oggie
Trader Score: (1)
FR rims rusting in the center cap area
On Thursday, I’ve gotten my front rims replaced under warranty. Apparently, the front center bore where the wheels sit on the front axle, the axle is hallow and debris and water, etc. could get onto the back of the center cap area to cause rust. I had my two rims replaced and I am going back into the dealership to get my bearings replaced as well on Monday. Service manager said Infiniti should be coming out with a permanent fix soon. In the meantime, he suggested that I should be cleaning up that area regularly. There was another demo G37S in the waiting area and it had the same problem as well. I believe this problem is most noticeable for cars that see winters using factory rims with snow tires.
fr-rims-rusting-in-the-center-cap-area-img_1650.jpg  fr-rims-rusting-in-the-center-cap-area-img_1651.jpg  fr-rims-rusting-in-the-center-cap-area-img_1652.jpg  fr-rims-rusting-in-the-center-cap-area-img_1653.jpg  fr-rims-rusting-in-the-center-cap-area-img_1655.jpg
__________________
2008 G37S IP | 5AT | Tanabe Exhaust+Y-Pipe | GTSpec STB | HID Fogs | Hotchkis Sways
Oggie is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-28-2009, 06:50 AM   #2
myk1013
Trader Score: (2)
wow, I thought our stockies were aluminum?
__________________
DarKSidE | 671 StreeT KingZ | iLLesT | STOCK OPTIONS
myk1013 is offline   Reply With Quote
Old 03-28-2009, 08:40 AM   #3
DrJones
Trader Score: (1)
Send a message via Yahoo to DrJones
got any pictures?
__________________
Rolling it back a bit: 2010 MazdaSpeed3 + 2010 Mazda 3 s Grand Touring Sedan
DrJones is offline   Reply With Quote
Old 03-28-2009, 09:14 AM   #4
w0ady
w0ady's Avatar
Trader Score: (1)
Send a message via AIM to w0ady Send a message via Yahoo to w0ady
interesting. pics would be helpful.
__________________
09 athens 7at g37s coupe 12/22/08; 05 athens 5at g35 coupe r.i.p. 5/13/05-10/29/08
w0ady is offline   Reply With Quote
Old 03-28-2009, 09:51 AM   #5
vINCe_Inc
Trader Score: (0)
hmm. mine is like that too
but i though it is normal >? no ? and i dont understand why your rims got replaced when its aluminum...?
__________________
[G37S] 6MT-Premium-Nav-Tech-Wing-Ivory Pearl-Graphite Interior-Tint-Sex?
vINCe_Inc is offline   Reply With Quote
Old 03-29-2009, 10:25 AM   #6
Oggie
Trader Score: (1)
I believe even aluminum rust too, although not as fast as steel would. Otherwise, I can't explain why I am having this problem.
__________________
Old 03-29-2009, 10:58 AM   #7
vINCe_Inc
Trader Score: (0)
hmm. did you use harsh acid cleaners ?
__________________
Old 03-29-2009, 07:32 PM   #8
myk1013
Trader Score: (2)
Quote:
+1 on this question.
Those pics look horrible. Doesnt look like rust from the pics. Looks like something ate away at the paint and coating. Even the center cap is jacked, isn't that made of plastic.
__________________
Old 03-30-2009, 09:31 AM   #9
Tainui
2008 Infiniti G37
Trader Score: (1)
This is what winter does to wheels but usually not for a few years. Road Salt sux.
Tainui is offline   Reply With Quote
Old 04-01-2009, 01:01 AM   #10
Oggie
Trader Score: (1)
Soap only
__________________
Old 04-01-2009, 07:09 AM   #11
Blackjack
2009 Infiniti G37
Blackjack's Avatar
Trader Score: (3)
Send a message via AIM to Blackjack
Those effects on aluminum are typical when using harsh detergents. Are you sure you are being honest? This can also be caused by road salt if not cleaned regularly as another poster mentioned.
__________________
09 G37S Coupe 6MT -- Moonlight White | Graphite | Premium | Nav | Tech | 4WAS | ClearBra | 35% FormulaOne Tint | KW Variant 3 | SPL Pro Rear Camber Kit | Vossen VF051 Custom |
RIP -- 08 G37S Coupe 5AT 11.2007 - 02.2009
Maintained with products exclusively from Detailed Image
Blackjack is offline   Reply With Quote
Old 04-01-2009, 11:26 PM   #12
Oggie
Trader Score: (1)
Gentlemen, honesty has nothing to do with the type of soap that I use.
In Toronto, the roads are salted and I used good quality car soap to wash my car. I can accept/expect rust around my wheels if they were 5 years old or so, But I only had my car for 5 months, it doesn't make sense that the wheels are already rusting.
The reason why I have rust around the center caps is due to the fact that the center bore is hollow in the middle where road salt gets into the back of the wheel caps. Take your wheels off and you will see. Furthermore, if you take off your front wheels and compare against your rear wheels, you will see the back of your rear wheels are cleaner and no rusty coloration but the front wheels do.
__________________
Old 04-29-2009, 01:57 PM   #13
AndrewDDS
2008 Infiniti G37 Coupe
Trader Score: (2)
^1. When I was swapping out my wheels a few weeks ago, I noticed that inside of my front bores were filthy. I think there was still road salt caked in there from months ago. Now that I'm aware of it, I'll be a lot more careful to keep that area clean every time I take my wheels off!!
__________________
'08 G37S - Blue Slate | 35% Tint | Eibach Pro Kit | Blue Slate Stillen splitter | 15mm Ichiba spacers | KP Tech Nav Bypass | KP Tech Window Module | Custom Arc Reactor | Interior LEDs
AndrewDDS is offline   Reply With Quote
Old 04-29-2009, 08:18 PM   #14
DrJones
Trader Score: (1)
Quote:
+1... but hey as long as you get it replaced!
__________________
Old 04-29-2009, 08:23 PM   #15
aliiin
Trader Score: (4)
i don't think aluminum can rust
__________________
I'm a noooooooooooooooooooob who doesn't remember to log out.
aliiin is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
