| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#16 |
there is now a revised version of this bulletin.
for some reason the bulletin now requires an oil / filter change
__________________
Thanks to Enkreuz, Stillen, Ultima Finish Care, Import Image, and Danase Detailing Supply |
#17 |
#18 |
someone give me an e-mail to send it to, and you can host it
__________________
#19 |
I went to the dealership a few weeks back to get their special nissan oil change and the noise is still there
#20 |
Did they do the ECU reprogram/reflash like the TSB shows?
__________________
G37 6MT, Premium, Nav. - Berk HFC, JWT intake, Stillen Grounding Kit, Fast Intentions Carbon Fiber Exhaust, KP Technologies Nav Bypass, Magden Performance Computer, HPA HIDs, SPC front control arms and rear camber/toe kit, Cobb AccessPort[/i] |
#21 |
yes they did the problem was still there and that noise been pissing me off for the past few months
#22 |
#23 |
sounds like the valves were tapping
#24 |
I also have this problem but it seems to go away when you give it some gas and hit about 3 - 4k rpm. and then let off the gas. Noise just comes right back and a buddy of mine thinks it's a lubrication issue or there's not enough oil pressure in this spot of the engine. Why would Nissan change the oil spec. if this was not the problem? All I know if Nissan doesn't fix this they will ether replace my engine or give me a new G37. Metal on metal sounds are not good! What about the wear on these parts that are hitting each other right now and what engine damage does this do? My car is also eating a 1/2 quart of oil as well. I don't know about this and is making a little nervous. Car is going into the shop for this TSB and I'm not accepting it back without it being fixed!
#25 |
2008 Infiniti G37 Coupe |
i wish someone would record this so i know exactly what this sounds like
__________________
2008 IP G37-- Homelessdrunk -- GT-Spec |
#26 |
Depending upon how old you are, it sounds like an old fashioned rod knock, only after the car is fully warmed up, only at idle, and only from the driver's side.
Since the "problem" is software derived and fixed, having the dealer read the current software version (which, btw, is the first step in the TSB to determine if the vehicle needs the update) is a sure fire way to find out if you need the upgraded software. |
#27 |
I'm having this issue as well. I just know when I go into the dealership they are gonna give me a hardtime, even if I tell them there is a TSB out on it. It took me 5 dealership trips and going through corporate and finally getting their shop foreman to ride with me and their GM to personally work with me to get my muffler replaced and my bad synchro's taken car of. Not to mention I'm positive my throw out bearing is seized and damaging my clutch but they say its a normal sound....
__________________
2008 G37S 6MT - Athens Blue/Stone Interior - Sport Premium Navigation |
#28 | |
Quote:
There has been an update on that tsb just so you all know the reprogram was only half the fix i have done the new tsb to 3 now and no more complaints. |
#29 | |
Quote:
I'm having consumtion issues which is why they recommend an oil change for me. They also mentioned that the Valve sound should go away.
__________________
G37S-6MT |
| Thread Tools | |
| Display Modes | |
