Cobb Accessports are now in the building!! Just like our Injen and HKS Sale threads, these bad boys are priced to go. Cobb Tuning makes it super easy to make additional horse power with bolt on mods. The Cobb Accessport plugs in, is super user friendly and has gains of up to 11HP and almost 6ft lbs of torque. If you need to take your G37 back to the dealer, no problem, the Cobb Accessport gives you the ability to flash the car back to stock just in time for some warranty work.
- To check out more info on the Cobb Accessport check out this link - http://cobbtuning.com/products/Default.asp?id=4278
** Part #AP-NIS-004 : Cobb Accessport Infiniti G37 : PM for Pricing **
<table align="center" border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td colspan="2">
Unlike other tuning options, the AccessPORT is truly unique in its capabilities that go far beyond typical “chipping” or “reflashing” solutions. This is where the AccessPORT clearly stands out from the competition:
</td> </tr> <tr> <td style="vertical-align: top;" height="60" width="20%">
</td> <td valign="top">
Simple Installation - Just about anyone with even the most basic of automotive knowledge can quickly and easily install an AccessPORT. No computers, wire cutting/splicing or tools of any kind are required.
</td> </tr> <tr> <td style="vertical-align: top;" height="90" width="20%">
Base Maps - COBB Tuning provides several preloaded maps for common power modifications. Each base map is dyno developed and rigorously tested in multiple COBB Tuning facilities across the country These tests cover the spectrum of altitude, temperature, humidity, octane and fuel quality variables to ensure proper calibration and performance wherever the car is driven.
</td> </tr> <tr> <td style="vertical-align: top;" height="105" width="20%">
Change Maps - Since all base maps and custom tune maps are stored in the AccessPORT, you can change maps any time you want. Switch to a race gas map for that extra performance at the track. Go to the Fuel Economy map for those long boring drives. Load the Valet map to keep revs below 3,200 when you drop your car off with the parking attendant. The Anti-Theft map does not allow the car to start, keeping it safe in suspect areas or during extended parking.
</td> </tr> <tr> <td style="vertical-align: top;" height="68" width="20%">
Performance - Turn on your own portable performance evaluation suite! Measure 0-60mph time, 60 foot and 1/4 mile ET’s and Trap Speed. Switch to Dynamometer simulation and calculate your vehicle’s horsepower and torque.
</td> </tr> <tr> <td style="vertical-align: top;" height="75" width="20%">
Live Data - Monitor OEM sensor data on-the-fly. Use the AccessPORT as an additional gauge to monitor a huge number of signals, like: RPM, Coolant Temp., Battery Voltage, Intake Air Temp., Ignition Advance, Mass Air Flow, Intake and Exhaust Cam Advance and many more!
Datalogging - Onboard datalogging allows multiple channels of data to be recorded simultaneously for later review. This allows for analysis of current engine performance. Datalogs can be sent to professional tuners to provide additional power gains remotely through email!
Trouble Codes - The AccessPORT allows you to read engine codes to troubleshoot issues and potentially save you from an expensive trip to the dealership. Once the issue is resolved, clear the codes and turn off the check engine light.
Uninstall - In the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition. Perfect for trips to the dealership.
</td></tr></tbody></table>
Call us at 866-703-8794 to order or get pricing. Have some questions? Just ask our very up to date Sales Team! Visa, Mastercard, American Express and Discover Cards accepted. Local Cash Pickups also welcome but please add 7% Sales Tax. 2% Cash Discount on top of sale pricing also applies.
Thanks
Rick
Import DPS
www.importdpsonline.com
