Radio presets WTF, mate?
Old Jul 18, 2008 | 03:52 PM
jnifong's Avatar
jnifong
Has anyone experienced this? I have the 6 presets set in my car. Using the toggle on the steering wheel to go up and down I noticed that for some reason if I start at the first preset and hit down it goes 1, 2, 3, 4, then back to one. Usually the station selected is high-lighted, but the 4th preset doesn't high-light. If I start at 1 and press up on the toggle, it will hit 6, 5, 4, then back to 6. I can't go straight in order. Did I confuse anyone? I might try re-doing the presets to see if that fixes it.
jon
__________________________________________________ _______________
08 G37S 6MT Black/Black Premium Navi
Shirts to bring out the wrong in you:
http://www.sheepholetees.com
Old Jul 18, 2008 | 04:28 PM
MoDat's Avatar
MoDat
I'll translate:
"For some odd reason my radio presets are messed up. For example.. When I start at preset 1 and go down... it skips over preset 5 and 6 and goes back to 1.
It does the same thing in the opposite direction. When I start at preset 6 and go in reverse, it'll skip over presets 3,2, and 1.
I might try redoing all my presets and seeing if it fixes it. Anyone else have any suggestions?!"
Your welcome.
Last edited by MoDat; Jul 18, 2008 at 04:28 PM. Reason: I apparently cant type either
Old Jul 18, 2008 | 04:53 PM
bfranks's Avatar
bfranks
jon
That fixed it for me.
Old Jul 18, 2008 | 06:12 PM
jnifong's Avatar
jnifong
Originally Posted by MoDat
I'll translate:
Your welcome.
Thanks for the translation. My brain was scrambled.
jon
Old Jul 18, 2008 | 06:46 PM
MoDat's Avatar
MoDat
jon
Did resetting the presets work for you?
Old Aug 8, 2008 | 10:12 AM
Kidcane's Avatar
Kidcane
Florida G Club
This started happening to me last night. Its pissing me off. Sometimes if I toggle it real fast I can go through all the presets but if I stop on one, the "A1" (or whatever preset it is) turns in to just an "A", then I cant flip through any presets unless I go the other direction, then I can only go to A2 and A3 before it stops again.
Old Aug 8, 2008 | 10:20 AM
Blackjack's Avatar
Blackjack
It happened to me yesterday as well for about the 3rd time since I got the car... Simply resetting your presets works fine. Still annoying though.
Old Aug 8, 2008 | 10:29 AM
IP37's Avatar
IP37
i think there is a tsb on this. never read it though
Old Aug 8, 2008 | 10:34 AM
Raizon's Avatar
Raizon
Guess I'm not the only person experiencing this problem. Whenever I get to A1, it doesn't allow me to switch channels using the toggle on the steering wheel. I have to manually push the buttons on the radio to change preset. I'll try resetting all my presets and see if that will fix the problem.
Thanks,
Rai
Old Aug 8, 2008 | 11:16 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
What the heck? This just happened to me too for the first time... Crazy how a lot of "first-timers" with this problem all experienced it yesterday... Kinda FREAKY IMO... So re-setting the presets should fix it? I was gonna take it to the dealer....
Old Aug 8, 2008 | 11:19 AM
Blackjack's Avatar
Blackjack
Yup that works... There is a TSB out on it, but I can't track down the PDF document.
Old Aug 8, 2008 | 11:56 AM
marsb007's Avatar
marsb007
there's also a thread on this same subject a few months old already... do a search. Best we could come up with at that time was the same thing as you guys figured out...
Set the preset to another station, then back to the original.
Happened to me twice in a year of having the vehicle. Not that big of a problem...
Old Aug 8, 2008 | 12:30 PM
IP37's Avatar
IP37
probably a mess, but i just copied and pasted the text from the pdf......
EX35/G35/G37/M/QX56; RADIO WILL NOT SCROLL THROUGH ALL PRESETS
(NAVI-EQUIPPED ONLY)
APPLIED
VEHICLES: 2008 EX35 (J50) WITH NAVI
2007-2008 G35 (V36) WITH NAVI
2008 G37 (CV36) WITH NAVI
2007-2008 M (Y50) WITH NAVI
2008-2009 QX56 (JA60) WITH NAVI
APPLIED VIN /
DATE: EX35 2WD vehicles built before: JNKAJ09E(*)8M306060 / 3-18-08
EX35 AWD vehicles built before: JNKAJ09F(*)8M360417 / 3-18-08
G35 2WD vehicles built before: JNKBV61E(*)8M220079 / 3-21-08
G35 AWD vehicles built before: JNKBV61F(*)8M269306 / 3-21-08
G37 vehicles built before: JNKCV64E(*)8M125026 / 3-21-08
M35 2WD vehicles built before: JNKBY01E(*)8M500896 / 3-25-08
M35 AWD vehicles built before: JNKBY01F(*)8M551256 / 3-25-08
M45 2WD vehicles built before: JNKAY01E(*)8M606732 / 3-24-08
M45 AWD vehicles built before: JNKAY01F(*)8M655078 / 3-24-08
QX56 vehicles built before: 5N3AA08(**)9N900007 / 4-9-08
IF YOU CONFIRM:
Preset A, B, or C does not scroll through all six (6) preset stations.
ACTION:
Replace the A/V Control Unit
• Go to Service Manual section “AV” for replacement procedure.
PARTS INFORMATION
Please reference the Infiniti Electronic Exchange Matrix in NNAnet as the main resource for the applicable
audio exchange unit part number.
CLAIMS INFORMATION
Submit a Primary Failed Part (PP) line claim using the following claims coding:
DESCRIPTION PFP OP CODE SYM DIA FRT
RPL DVD/NAVI Control Unit and
Return To Manufacturer (1) RN87RA HB 32 (2)
1. Reference the Infiniti Electronic Exchange Matrix in NNAnet and use the indicated audio exchange unit P/N as the
PFP.
2. Reference the current Infiniti Warranty Flat Rate Manual and use the indicated FRT.
Infiniti Bulletins are intended for use by qualified technicians, not 'do-it-yourselfers'. Qualified technicians are properly trained
individuals who have the equipment, tools, safety instruction, and know-how to do a job properly and safely. NOTE: If you believe
that a described condition may apply to a particular vehicle, DO NOT assume that it does. See your Infiniti dealer to determine if this
applies to your vehicle.
Old Aug 8, 2008 | 12:32 PM
Blackjack's Avatar
Blackjack
^^ Wow.. So they replace the who A/V control unit??? Hell I may take mine in next time and let them do it.
Old Aug 8, 2008 | 01:12 PM
gmlee86's Avatar
gmlee86
Yeah mine started acting up yesterday too.. weird.. but resetting the presets yesterday didn't fix it. Haven't driven the car today to check but might have to take it in for service next week before I leave for NM
