MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > MODDING 411
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Closed Thread
Thread Tools Display Modes
Old 03-02-2008, 10:30 PM   #1
bboysteele
bboysteele's Avatar
Trader Score: (0)
Brakes
AP Racing AP Racing 6-Piston Big Brake Kits
For the biggest brake system upgrade, Brake Pros offers world renown AP Racing 6-piston calipers running on 2-piece rotors. Each kit is designed to work with the original equipment master cylinder, ABS and traction control systems. Specially-designed 2-piece rotors are cross-drilled and slotted, the optimum for high-performance street, autocross and occasional track day use. Slotted-only versions are available for the serious track enthusiast. The curved vane construction provides maximum cooling, while significantly reducing unsprung weight.
DOT-compliant and TÜV-approved stainless steel lines are included to top off the upgrade and provide a huge improvement in pedal feel and stiffness. Brackets and hardware are made from aerospace-grade materials and high-strength fasteners. All AP Racing kits are complete with no other parts required. Install, bleed and go!
Stillen Product Link
AP Racing AP Racing 4-Piston Big Brake Kits
For a big upgrade at an affordable price, Brake Pros offers world renown AP Racing 4-piston calipers running on 1-piece and/or 2-piece rotors. Each kit is designed to work with the original equipment master cylinder, ABS and traction control systems. Specially-designed rotors are cross-drilled and slotted, the optimum for high-performance street, autocross and occasional track day use. The curved vane construction provides for maximum cooling when pushing hard. 2-piece kits come with aluminum alloy hats for better thermal management and maximum weight reduction.
__________________
G37 6MT, Premium, Nav. - Berk HFC, JWT intake, Stillen Grounding Kit, Fast Intentions Carbon Fiber Exhaust, KP Technologies Nav Bypass, Magden Performance Computer, HPA HIDs, SPC front control arms and rear camber/toe kit, Cobb AccessPort[/i]
bboysteele is offline
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-02-2008, 11:52 PM   #2
bboysteele
bboysteele's Avatar
Trader Score: (0)
Stop Tech Big Brake Front Kit 08' G37 6 piston 380mm
Advantages of StopTech over other brake upgrades:
- Shorter Stopping Distances
- Better Brake Modulation
- Firmer Brake Pedal
- Less Brake Fade
Two Wheel Front Big Brake Kit Includes:
- 2 Piece Floating Directional 380x32mm AeroRotors
- 6 Piston ST-60 Calipers
- Stainless Steel Brake Lines (Front Only)
- Caliper Mounting Brackets
- Street Performance Pads (Front Only)
StopTech Website Link
Vendor Sale for Brake System
Stop Tech Big Brake Rear Kit 08' G37 4 piston 355mm
- Less Brake Fade
- 2 Piece Floating Directional 355x35mm AeroRotors
- 4 Piston ST-45 Calipers
__________________
Old 06-13-2008, 05:13 AM   #3
bboysteele
bboysteele's Avatar
Trader Score: (0)
STILLEN Sport Rotors - 1-Piece
STILLEN Sport Rotors are an exact size as OEM rotors; they offer maximum performance with stock calipers. Computer Aided Design (CAD) is employed to determine the optimum pattern for any size rotor. This pattern is critical, for it must correctly sweep the brake pad to increase its initial bite and allow for out gassing while also cleaning the entire brake pad surface. The sweep will eliminate hot spots and maximize the brake pad friction to the rotor. The added air surface, created by cross drilling, will increase the rotors ability to dissipate heat and cool more effectively. For Sport Rotors to perform at their best, they should be used in conjunction with STILLEN Metal Matrix Brake Pads. Actual product may vary slightly from image.
Stillen Web Page
__________________
Old 09-15-2008, 04:36 AM   #4
bboysteele
bboysteele's Avatar
Trader Score: (0)
Goodridge Gstop Stainless Steel Brakeline Kits
Brake lines are one of the single best upgrades to your braking system possible.
Goodridge stainless steel braided brake lines have become the standard in professional motorsports where the ultimate in braking is required. There is no room for volumetric expansion, or “mushy brakes” caused by rubber lines. A highly efficient braking system allows you to get deeper into the corner and onto the accelerator faster.
Additionally, when G-Stop brake hoses are used with an ABS braking system they virtually eliminate brake pedal “chatter” and significantly reduce stopping distance. The advantages of Goodridge G-Stop Brakelines are not only for the high performance vehicles; they are also a terrific performance enhancement and safety improvement on the “daily driver”.
A reduction in braking distance during a panic stop can reduce the possibility of accidents and save lives. It’s features like this that make Goodridge G-Stop Brakelines the most cost-effective safety improvement you can make on any vehicle. G-Stop brakelines conform to all federal requirements of FMVSS106, making them D.O.T. Certified and T.U.V. Approved (Germany).
All Goodridge G-Stop brake lines go through a 9-point Quality Assurance testing process including tensile strength and pressure testing to 3000 p.s.i. before leaving our facility. To ensure proper fit and easy installation, special end fittings and line brackets have been produced to fit identically to each vehicle. The exclusive Goodridge “Forever Guarantee” covers G-Stop Brakelines.
Link to Product
__________________
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
