MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > MODDING 411
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Closed Thread
Thread Tools Display Modes
Old 03-02-2008, 07:09 PM   #1
bboysteele
bboysteele's Avatar
Trader Score: (0)
ECU/Chip mods & managment systems
IMPUL HI-POWER CONTROL UNIT
Bring out vehicle potential sufficietly!
- Increase maximum power.
- Improve engine response and mileage.
Impul link
__________________
G37 6MT, Premium, Nav. - Berk HFC, JWT intake, Stillen Grounding Kit, Fast Intentions Carbon Fiber Exhaust, KP Technologies Nav Bypass, Magden Performance Computer, HPA HIDs, SPC front control arms and rear camber/toe kit, Cobb AccessPort[/i]
bboysteele is offline
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-03-2008, 04:17 AM   #2
bboysteele
bboysteele's Avatar
Trader Score: (0)
PLX Devices DM-100
Intelligent Multi-Functional Display (iMFD)
Universal 2 1/16" (52mm) OLED Color Display for all Sensor Modules
Customizable gauge styles, backgrounds and colors
Analog, Digital, Graph, 4 Parameter styles
Organic LED display
Set peak and hold points
Intelligent warning
Daisy Chain up to 32 Sensor Modules
Simple to Install
PC Interface Software Included
Comes with Remote Control
Additional modules and addons available
PLX Manufacture Site
Vendor Thread
__________________
Old 08-15-2008, 03:16 AM   #3
bboysteele
bboysteele's Avatar
Trader Score: (0)
Blitz Throttle Controller
*Electronic device that improves the accelerator response drastically.
*Blitz configured original 4 settings (ECO/SP1/SP2/SP3) to select desire acceleration response by simply pressing a button. Or "OFF Mode" also available if/when stock accesleration needed
*Monitor clearly displays selected mode all the time while in use.
*Vehicle specific plug and play kit includes all necessary harnesses.
*Automatically return to "OFF Mode" at each time engine shuts off as a safety feature.
*Reverse Cancel Cable available as option which disables the function while in reverse.
Blitz Webpage
Vendor Thread
__________________
Old 09-14-2008, 05:08 PM   #4
bboysteele
bboysteele's Avatar
Trader Score: (0)
Magden M.1b Performance Computer
This Performance Computer comes ready to show you a variety of data channels your vehicle has but which the factory doesn't show you. The M.1b connects to your vehicle's OBD-II connector inside the car (equipped on 1996 and later vehicles) and will deliver some critical data channels that aren’t available with standard gauges. For example; Ignition Timing, Throttle Position and Air Intake temperature are just a few seen on most vehicles. Use these gauges to validate your performance upgrades. The M.1b can datalog as well, saving the information you need to help analyze your vehicle's performance. Click on some of the thumbnails above to see some M.1b screen shots.
The M.1b is also equipped with Dynamic Horsepower and Torque gauges. By simply doing the Power Runs before and after you install upgrades, you will see the difference. It makes evaluating your performance upgrades easier than before.
Customization is key. Set the M.1b the way you want. Choose a gauge layout and then choose which five gauges to view. Continue customizing by choosing which skin, indicator colors and gauge text color you prefer. It is loaded with many options to pick from, so matching your interior or creating something totally unique is possible.
Installing gauges has never been easier. Simply connect the OBD-II, Video and power cables and you're ready to experience new guages on your LCD screen. No more cluttered interior or difficult gauge installations. If you don't have an LCD screen, look in our Products section for some to choose from.
Part Number: M1P1-0001
Contents:
M.1b Performance Computer.
OBD-II cable.
Cigarette Adapter Power Cable.
1GB USB Memory Stick (Owner’s Manual loaded on it).
Quick Start Guide.
Features:
Loaded with 3 gauge layouts; Secants, Datalab and Traditional.
Choose any 5 gauges to view per layout.
10 different skins to choose from.
See various OEM data channels.
Unit of measure choice for selected gauges.
Delivers Gear Position, Dynamic Horsepower and Torque, and real time Fuel Mileage gauges.
Datalogs any 5 gauges at a time.
Replays the data-logged session on the screen.
Exports the session as a .CSV file for viewing on any computer.
Outputs your choice of VGA, S-Video or Composite video to accommodate various LCD screens. A DVI and LVDS video card upgrade is available.
Benefits:
Provides hard data to evaluate performance upgrades.
The M.1 eliminates a cluttered interior with standard gauges.
Provides access to vehicle efficiency and critical functions.
Quick connections and easy installation.
Compact size with expandability.
Minimal power consumption.
Graphics can match most interior color schemes.
Choose data channels to focus on your driving style.
Works with most common LCD video screens.
Specs:
Dimensions: (L) 7” x (W) 7.325” x (H) 2.30” / 177.8mm x 186mm x 58.42mm.
Exterior Case: ABS Plastic.
Weight: 2.0 lbs.
Amperage draw: 1.2 amp peak, .86 amp continuous.
Inputs: DB9M OBD-II, USBx2, Ethernet, DC power plug.
Outputs: VGA Female, Composite Video, S-Video. DVI/LVDS and Additional Sensor card optional.
Cigarette Power Adapter; 6-foot cable, Power LED indicator, DC 2.5 x 5.5 plug with locking collar and 3-amp fuse.
OBD-II cable, 6-foot length, 90 degree, right hand OBD-II connector, DB9F straight connector.
Notes:
M.1b requires a USB memory stick for data-logging. Any memory size is compatible and will determine the amount of data-logging available.
Works with most vehicles equipped with OBD-II (1996 - current). Please check the application page for validated vehicles.
Link to Application/Channel list
Manufacture Website
Vendor Thread
__________________
Old 11-11-2008, 10:14 PM   #5
AZg37
AZg37's Avatar
Trader Score: (7)
Send a message via AIM to AZg37
Cobb AccessPORT
The AccessPORT is the first hand-held device available for the Infiniti G37 that performs an ECU reflash through the vehicle's OBDII port. Just plug it in, load the map and go! Faster!
The AccessPORT provides owners of 2008 Infiniti G37 vehicles the ability to unlock power hidden within the factory ECU. Performance gains across the entire powerband can be quickly realized in the short time it takes to flash the vehicle's ECU with the AccessPORT. No tools are required. No mailing the factory ECU across the country. No vehicle downtime. No waiting. And waiting. And waiting! Just plug the AccessPORT in, flash the ECU and enjoy the thrill of increased torque and horsepower!
Flashing the ECU is just the start of what the AccessPORT is capable of. Set the AccessPORT to Performance mode toview 0-60MPH times, ¼ Mile times and Speed Traps. Switch over to Live Data and choose a gauge to monitor, such as; coolant temperature, oil temperature, throttle position, intake cam advance, Air/Fuel voltage and many more. Use the Troubleshooting mode to diagnose issues across multiple electronic control systems (ECU, TCM, IPDM, M\A Meter, BCM, Auto Drive Position, Pre-Crash Seatbelt System, Adaptive Lights and Air Bag System) by reading the factory codes and resetting the system once the issues have been resolved.
Protect your investment when out on the town by quickly loading the Valet map to prevent the engine from revving above 3,200 rpm. When it's time to put the G37 away for the evening, simply load the Anti-Theft map to make it impossible to start. And in the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition.
The AccessPORT will continue to meet future needs as well. Firmware upgrades will include the ability to record datalogs, monitor fuel economy and simulate a dynamometer. Upcoming software releases will enable our Professional Tuner network to custom tune any modification configuration to extract the maximum performance from each unique vehicle.
The AccessPORT from COBB Tuning is the most comprehensive hand-held ECU flashing, monitoring and managing device available for the Infiniti G37.
Part No. AP-NIS-004
Link To AccessPORT page on Cobbtuning.com
__________________
Stillen Pulley|Akebono BBK|Grounding Kit|5% Tint
AZg37 is offline
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
