Go Back   MyG37 > Tech Area > Engine, Drivetrain & Forced-Induction > MEDIA SHARE
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 09-07-2009, 02:48 PM   #61
tristan1334
2008 Infiniti G37
My Garage
Trader Score: (0)
Send a message via AIM to tristan1334 Send a message via Yahoo to tristan1334
Quote:
Originally Posted by Q8y_drifter View Post
Can you elaborate on the 70% throttle at WOT?
As you may know our car utilizes a Drive By Wire throttle. The throttle plate only opens a 70% when the gas pedal is floored not your usual 100%. I'm sure you've noticed the slight delay when you floored it.
According to the throttle tables, when you're pedal position is on 86% you're throttle plate is only opening at 52%. I'm not sure if there is a good reason why nissan did this.
__________________
IP G37s 6MT - AAM HFC and Y-pipe, Cobb AP and K&N's -->13.29@105.98mph
tristan1334 is offline   Reply With Quote
Old 09-07-2009, 06:31 PM   #62
G37Sam
Post whores must die!!
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Send a message via MSN to G37Sam
^ Overheating issues => Limp mode?
More fuel burnt = more heat released
G37Sam is offline   Reply With Quote
Old 09-07-2009, 06:57 PM   #63
tristan1334
2008 Infiniti G37
My Garage
Trader Score: (0)
Well, I didn't change the WOT I left it at 70% but I did increase the throttle response to 2% across the rpm range. I guess it's similar to having a throttle controller.
__________________
Old 09-07-2009, 07:01 PM   #64
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
I would love to try and open it up to at least 90% especially with upgraded intakes those should make quite a decent difference.
Old 09-07-2009, 07:11 PM   #65
tristan1334
2008 Infiniti G37
My Garage
Trader Score: (0)
Same here but I wouldn't go that far yet. I'm debating about bumping it up to 75%. I need to talk to a tuner that have an idea on how our VQ and VVEL works. I want to know if it's ok to put more air in since I know I'm running a bit rich.
My car needs to be serviced soon. Maybe I can try it out on the loaner car and see how it goes, hmmm...
__________________
Old 09-07-2009, 09:02 PM   #66
Q8y_drifter
Trader Score: (0)
Is this throttle limiter adjustable via the Cobb AP? Do all cars have such a limiter? Also, is this limit only present at certain speeds or gears? (such as flooring it at 70mph vs. a stand still)
__________________
08 Skyline 350GT Sedan
Q8y_drifter is offline   Reply With Quote
Old 09-07-2009, 09:09 PM   #67
chamelieon
450whp or Bust!!
chamelieon's Avatar
Trader Score: (1)
Send a message via AIM to chamelieon
yes its adjustable with the cobb ap, yes all modern cars have this limiter, pretty much anything that is drive by wire has these limitations, some way worse than others, all for safety and emissions reasons. the G is programmed to only allow 25% throttle until after 3k rpms, so that if your slowly rolling you dont spin out of control. all the limitations on the car are to make it very driver friendly so your grandma doesnt spin out into a tree. this causes a very unresponsive car when we are trying to push the balls out of it.
the throttle tables are pretty ****ty to begin with, at %56 percent foot throttle the butterfly are only open like 20% ..its pretty bad. BUT the full throttle limit is %87 and thats because the difference between 80-100% throttle is 1% power difference, but keeping the throttle slightly closed causes better atomization and emissions.
__________________
08 G37S PG - www.NoLimitMotorSport.com
chamelieon is offline   Reply With Quote
Old 09-07-2009, 09:13 PM   #68
chamelieon
450whp or Bust!!
chamelieon's Avatar
Trader Score: (1)
Quote:
Originally Posted by Seer View Post
actually if you want to get even more technical... an NA internal combustion motor pretty much works the same throughout the entire spectrum.
You want it slightly richer at peak torque, then lean at peak hp.
EX: 12.7:1 to peak torque, and 13.0:1 at peak hp.
I've built a few 800hp+ motors before, na and FI. FI obviously you want to go way richer.
yes! glad someone else here knows their sh*t!
__________________
Old 09-09-2009, 12:48 PM   #69
flipside6400
2009 Infiniti G37
Trader Score: (0)
Send a message via Yahoo to flipside6400
thanks for final clarification !!!!!
flipside6400 is offline   Reply With Quote
Old 10-24-2009, 04:01 PM   #70
camNili
Trader Score: (0)
Im lovin it
__________________
'08 IP G37 Coupé | Injen CAI | Blacked Out |
camNili is offline   Reply With Quote
Old 11-17-2009, 03:41 AM   #71
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Really??? That's why the G feels so sluggish! I guess that's what makes the Z "feel" faster
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
