MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Engine, Drivetrain & Forced-Induction > MEDIA SHARE
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 11-11-2009, 08:28 AM   #76
some1
Trader Score: (0)
my black G
some1 is offline   Reply With Quote
Old 11-11-2009, 11:01 AM   #77
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Send a message via MSN to G37Sam
Pushing 357whp? Can you give us more details please?
How many psi? What exhaust? 5AT or 6MT?
G37Sam is online now   Reply With Quote
Old 11-21-2009, 11:49 PM   #78
kame_sanjo
2008 Infiniti G37
Trader Score: (1)
ok sorry ive been away so long! havent had time to even drive the car =P
just went to a dyno day today. good and bad news, good power but bad a/f! so need to talk to sam soon about a new tune or possibly bigger pump.
Photobucket
thats at 9.3 psi. so im very satisfied! just need to re-tune.
__________________
OB 6MT VQ37HRTT - GTM 3" Exhaust - Stillen pulley - F.A.S.T. - Blitz SBC Spec-S
kame_sanjo is offline   Reply With Quote
Old 11-22-2009, 10:13 AM   #80
kame_sanjo
2008 Infiniti G37
Trader Score: (1)
there arent any numbers on it. dont know why.
__________________
Old 11-22-2009, 11:47 AM   #82
kame_sanjo
2008 Infiniti G37
Trader Score: (1)
sorry haha, the dang numbers are all the way at the bottom. im so used to looking at just the hp/tq. 515hp @ 6500rpm and 451ft/lb @ 4400rpm. and unfortunately the a/f was14.52 to 14.87 all the way through. at a lower boost the numbers are solid though.
__________________
Old 11-24-2009, 09:58 AM   #83
DmfG37sTT
STL's Finest
DmfG37sTT's Avatar
Trader Score: (0)
Good job man..for stage one the car makes good power for such a ****ty A/F. give us some goodie pictures of your baby!!
__________________
2008 G37S Coupe, 6MT, 2% Tint
DmfG37sTT is offline   Reply With Quote
Old 12-31-2009, 01:07 PM   #84
Ivoidwarranties
It's HER car.
2008 Infiniti G37
Ivoidwarranties's Avatar
Trader Score: (3)
Update? Are you happy with the car?
Ivoidwarranties is offline   Reply With Quote
Old 01-05-2010, 02:45 PM   #85
silver g
Trader Score: (2)
Quote:
Your A/F's are in the 14's at WOT!?!? If so you are running dangerously toooooooooooooooooooo lean!!!!! I would not drive that car or get it into boost at all until you get a re-tune. Your A/F's should be somewhere in between the 10-12 range at WOT. I apologize if it has been said but what size injectors are you running?
__________________
03 BS G35C 6MT - Team OUTCAST//APS Extreme TT//Cosworth VQ35DE//Corner 3//Street Works
silver g is offline   Reply With Quote
Old 01-07-2010, 01:44 PM   #86
SAM@GTM
MYG37.COM Sponsor
SAM@GTM's Avatar
Trader Score: (1)
Let's just pray to God that your AFR reading is wrong. There is no possible way that the engine can survive under boost at 14.7. I just went back and dug up a PM from a few weeks back that you sent me regarding this issue. My specific instructions were to stay out of boost and call me immediately. Before I give you any suggestions regarding fixing the problem, most likely there is a mechanical issue with the fuel system.
If the car is running the proper afr at a lower boost level, that indicates a possible loss of fuel pressure. When modifying the fuel pump assembly housing, it is very important to follow the instructions and drill the regulator orifice with the right size hole and be sure that your o-rings are not leaking. Otherwise, this problem will only appear at a higher fuel system demand. If the car was running lean all the time, it would indicate a possible tuning issue.
There are two things you can do.
1) Install a fuel pressure gauge on the system to verify fuel pressure. In the event that you see a dramatic drop in fuel pressure, or the air fuel ratio going into the 14's, get off the gas!
2) If you don't have access to a fuel pressure gauge, remove the fuel pump assembly and recheck the fuel system modification that you have done.
3) I don't see an air fuel ratio on the dyno graph, so i'm assuming that you are depending on something you have installed in the car. Please verify the air fuel ratio with a properly calibrated wideband.
It is really important for you to remedy this problem...you are playing with fire.
Sam
__________________
SAM@GTM is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
