- Stillen Grounding Kit- I can't decide
- Short Thow Shifters??
- Ne1 tried Motul oil?
- ECU self adjusting
- Rear Axle Squeek
- GTR Intake/Exhaust
- Vdc
- GT Motorsports: GTM Twin Turbo Systems for VQ DE, HR, and VHR Engines
- RPM Meter
- HR-TT Project Near Completion
- This ever happen to anyone else?
- G37 Twin Turbo kit
- Gasket
- Clutch/Transmission Problem? Need Help
- Tranny noise might be addressed
- Stillen g37 dual exhaust system
- Depressing clutch all the way or half way
- Clutch dead at 6.3k miles
- Enginte cut-off at 6200 RPM
- Clutch Getting stuck on the ground!
- check engine light at 500 miles
- For those of you who do your own oil changes..read up!!
- AC Questions
- Grounding kit. cant decide
- Odd Tapping On Startup? 6MT
- ECU which is best?
- G37 reflash in North Florida or around NYC?
- HFC installed- will void warranty
- Oil change questions
- Service Engine Soon light
- G37s With Ticking Noise From Engine
- Stillen Crank Pulley
- Exhaust Depot!
- Anyone got any feed back re: Pulstar pulse plugs?
- Transmission Question Auto/ Manual Mode
- Lower temperature thermostat
- Synthetic Oil
- ECU reset vs. ECU reflash
- Fluid leak at rear axle side flange
- Octane boosters!
- grounding kit on a 6mt
- Can I take my car to a Nissan dealership for an oil change?
- 15,000 Mile Service
- service engine light at 800 miles?
- Has anyone had the VVEL actuator TSB repair?
- How to Launch 6mt???
- IOS Performance????
- injen intake and FI exhaust
- 87 Octane
- Redid Dyno for Baseline
- Few mods and dyno to share
- Car Dyno'd today
- Any other performance options on the horizon
- Finally a REAL Jdm exhaust!
- TT on late model sedan
- ECU reset needed?
- Does anyone knows how i can find the ECU part # withut takeing the car to the dealer
- VDC, SLIP, 4WAS lights come on while driving?
- had problems with my G tonight :(
- Opinions on Dynoing the Injen Intakes... Need opinions...
- Installed Stillen Grounding Kit
- Power Loss Problem Solved??? - VERY Strange....
- Excessive water dripping from A/C
- Dyno g37s
- Oil Consumption Issue cured with G37?
- Stock Intake Filters
- VDC frustration
- I Got a couple Questions (look please :))
- Whats the most exotic sounding MUFFLER not exhaust?
- Break In Period?
- Grounding Kit
- 15,000 mile service
- TEST PIPES or HFC'S??
- Hyper Voltage Gt? vs Grouding Wires
- A thought about Intakes and ECU for the G37
- My G Got Operated On (success)
- Newb Question about HKS F-Con V Pro
- Y pipe vs X pipe....
- anyone using pulleys yet?
- Car not the same AFTER ECU TSB reflash :(
- Clutch Question
- air intakes for g37S
- Service Engine soon light came on
- strange voice
- nitrous ne one???
- Sould i delete resonator with stock exhaust?
- infinti to pay for part of aftermarket cat back
- DS > MM > D 5AT blows
- G37 turbo question
- Unichip or other piggyback chip
- synthetic oil
- Mobile 1 Oil
- Is this a joke
- Where is your RPM when going 50, 60, 70, and 80 mph?
- Cobb tuning needs help from someone in the Salt Lake City Area
- Dyno'd my G37 @ ZCarGarage
- Hks Camp 2
- braking problem and cracking noises.
- Idle RPM high and SES light on
- Engine idle issues when stopped
